t1mpani
Platinum Member
- Jun 6, 2002
Here are some shots of two knives that I've worked on recently. One is an Ontario Mk3 Navy Knife that belongs to a friend of mine--the original handle and hammer/pommel had been broken off somewhere along the way. He asked for a new handle and also for me to actually "make it a knife" which meant improve the edge geometry a bit so that it was a little better cutter. I made a few handles out of balsa wood so that he could try a few on, so to speak, and then made the real one out of canvas micarta based on the one he picked. Pretty much turned the blade into a scandi grind--the original saber made just an absurdly thick edge.
The other one is my own knife; a Gerber LMF II that I picked up at my local PX recently because they had a huge selection of knives (and other tools) marked down. Now, this is one of those knives that I've looked at before and decided against, because I absolutely despise serrations---and before anyone jumps in with how serrations saved them one dark and stormy night, I agree that there are certain types of cutting where they easily surpass a straight edge. It's just that they do not support my typical uses for knives, and tend to be more of a hinderance than a help to me. But, it was a good enough price that I decided I'd just make the thing into a recurve and kill the serrations, and if I messed up--either in the shaping or in letting the blade get too hot and messing up the heat treat, I wasn't out that much money. It turned out pretty well. I slimmed down the entire edge a bit to improve cutting ability. Doesn't quite "pop" hairs, but removes them pretty easily (it's still a saber grind, after all
). Since this won't be my whisker-removing instrument or whittler, I'll probably put a coarser microbevel on there to make it slice a little better. I like it more now than I originally did.
Warning--you're about to see some of the worst photography you've ever feasted your eyes on.
Anyway, here they are--the recurved Gerber up first (just a few shots):
http://i150.photobucket.com/albums/s115/t1mpani/Project knives/IMG_1331.jpg
http://i150.photobucket.com/albums/s115/t1mpani/Project knives/IMG_1332.jpg
http://i150.photobucket.com/albums/s115/t1mpani/Project knives/IMG_1339.jpg
And now the Navy knife, I lost my early shots of it with the broken handle, so the first is a link to Amazon's picture of one.
What it originally looked like:
http://www.armynavydeals.com/asp/images/product_images/CCMark3.jpg
Handle was broken, so remove:
http://i150.photobucket.com/albums/s115/t1mpani/Project knives/IMG_1303.jpg
Original edge bevel:
http://i150.photobucket.com/albums/s115/t1mpani/Project knives/IMG_1301.jpg
New convex edge bevel:
http://i150.photobucket.com/albums/s115/t1mpani/Project knives/IMG_1297.jpg
http://i150.photobucket.com/albums/s115/t1mpani/Project knives/IMG_1300.jpg
Inlet micarta scales for hidden tang and drill for corbies:
http://i150.photobucket.com/albums/s115/t1mpani/Project knives/IMG_1307.jpg
Roughen tang for acraglas adhesion:
http://i150.photobucket.com/albums/s115/t1mpani/Project knives/IMG_1308.jpg
http://i150.photobucket.com/albums/s115/t1mpani/Project knives/IMG_1309.jpg
Shaping:
http://i150.photobucket.com/albums/s115/t1mpani/Project knives/IMG_1310.jpg
http://i150.photobucket.com/albums/s115/t1mpani/Project knives/IMG_1311.jpg
http://i150.photobucket.com/albums/s115/t1mpani/Project knives/IMG_1312.jpg
Coat knife tang and interior of scales with acraglas, bolt together, let sit 36 hours:
http://i150.photobucket.com/albums/s115/t1mpani/Project knives/IMG_1313.jpg
Fit after curing:
http://i150.photobucket.com/albums/s115/t1mpani/Project knives/IMG_1314.jpg
http://i150.photobucket.com/albums/s115/t1mpani/Project knives/IMG_1315.jpg
Cut off remainder of bolts, sand smooth, final shaping and smoothing:
http://i150.photobucket.com/albums/s115/t1mpani/Project knives/IMG_1317.jpg
http://i150.photobucket.com/albums/s115/t1mpani/Project knives/IMG_1318.jpg
Strop new edge bevel to final shape, cut microbevel ten degrees steeper than plunge grind:
http://i150.photobucket.com/albums/s115/t1mpani/Project knives/IMG_1319.jpg
Not an invisible seam, but not bad. Harder to see in normal light:
http://i150.photobucket.com/albums/s115/t1mpani/Project knives/IMG_1327.jpg
Wink for the camera:
http://i150.photobucket.com/albums/s115/t1mpani/Project knives/IMG_124a.jpg
Let me know what you think--I'm not fragile. For what it's worth, the owner is happy with it.
Oh and yes, the original sheath still fits and snaps it in just fine.
Warren
Shaping:
Fit after curing:
Warren
