- Aug 23, 2002
A more rustic style of shot pouch made of alum tawed sheepskin and lined with linen. The flap of the pouch is made from the leg section and the edge was left as skinned. The linen lining adds a bit of fringe to the outer edge while a single row of white and blue beads decorates the edge seam. In the center is an embroidered hunters star aka compass rose. At the top edge of the flap a bit of deer hair trim adds a bit of color.
The pouch body is double welted and that has been fringed. There are two real repairs on the body one slip of the knife has been sewn together on the front and a braintan buckskin patch covers a small weak spot on the back. There's a leather divider inside making this essentially a two section pouch.
The pouch strap is made of bark tan calf skin and includes a 1 antique roller buckle for making adjustments. Attached to the front of the strap is an 80 grn powder measure made from a deer leg bone section and partially covered with deer rawhide and linen thread wraps.
On the back of the pouch is a strap with a bone toggle button that can be tucked under the waist belt or sash to keep the bag from swinging away from ones body. The front flap is closed with a hand made antler slab button.
The horn is an original SW Virginia horn (circa 1850s?). I repaired the small cracks along the butt with a bit of pitch and then covered it over with deer rawhide. I then added an iron ring for the bark tan cowhide harness strap at both ends and can be used alone or attached to the patch strap via a couple of small braintan thongs. The horn can be used alone or attached to the patch strap via a couple of small braintan thongs. The horn strap is adjustable via the two braintan buckskin thongs on each end. The whole set was given a patina of age used but not abused .
