Cyrano
- Jun 13, 2015
I find having a knife lay horizontally at the bottom of my pocket to be uncomfortable and inconvenient. I have some lovely knives which I rarely carry because they lack a pocket clip.
For knives which have a lanyard hole, I've used a short length of paracord to tether them to an off-the-shelf pocket clip like this one:
This solution (paracord + clip) is OK for transportation, as the knife carries vertically along the edge of the pocket. However, this solution has drawbacks:
One end of the nylon netting is fused closed with a hot knife. At its other end, one part of the quick-disconnect buckle is attached using hot-melt glue.
The other part of the quick-disconnect buckle is attached to the pocket clip, also using hot-melt glue:
The result is a thin, lightweight, and form-fitting sheath which can be easily connected/disconnected from the pocket clip:
My initial evaluation of this solution is positive:
- Getting the knife out of the pocket is somewhat inconvenient, as the pocket clip must be removed from the pocket.
- When the knife is in use, the pocket clip dangles off the end of the knife's handle.
- This solution works only for smaller knives. Larger knives have the lanyard hole too high in the pocket to make the combined length of (knife + clip) fit comfortably inside the pocket.
- This solution works only for knives with lanyard holes.
- The knife carries well, in a good vertical position along the edge of the pocket.
- The sheath adds very little to the dimensions of the knife.
- Getting the knife out of the pocket is convenient. The end of the knife extends past the top of the sheath, making it easy to grasp the knife and withdraw the knife from the sheath. The sheath and clip remain in the pocket.
- When the knife is in use, there is nothing attached to the knife.
- This solution should work for both small and large knives.
- In addition to allowing the use of a pocket clip, the netting provides protection for the knife while in the pocket. The netting can also be left on the knife to provide protection when the knife is not in use.
- Only one pocket clip is needed, with each knife having its own inexpensive bespoke sheath:
