A few more questions on folders...
Okay...sorry if this has been covered, but I am a slow learner sometimes!
Anyway, the questions:
1) I want the friction folder I am building to have an adjustable pivot tension. The only folders I own that are able to be taken apart are a REKAT Pioneer and Carnivore. Anyway, here's what the pivot seems to involve, although Neil Blackwood makes me believe I am missing something, so hel pme out if I am... The REKAT's have a hole drilled into the tang on the blade. Let's say it's 3/16" diameter, although I haven't measured it. In this hole a hollow, threaded tube is placed. This tube has a length that is LESS than the overall thickness of the folder itself (including scales, liners, pivot washer, and the blade itself) and into each end is threaded an allen-head screw. By tightening and loosening these screws (which cause the liners to exert more or less pressure on the washers and increase or decrease pressure on the tang), the tension on the blade is altered. Is this all there is to it? In other words, to make the adjustable pivot, I essentially need a hole in the tang, a threaded tube of the same outer diameter, and two screws that match the inner threads on the tube (plus countersinks and all that if I want to make it look nice). That's all it looks like I need looking at REKAT's stuff, but am I missing something???
2) I was originally planning to have an open back sort of design, where I would get some stainless rod, drill it, and tap it for some tiny screws I have (thanks, Maddog). These are the same 2-56 screws that REKAT also uses. Anyway, it looks like the precision needed for this job may exceed the tools I have at my disposal, so I was thinking of two alternatives. One is using a metal spacer that I drill and tap (may be easier to do on this material than on a rod), or the other idea is to use a material like wood or possibly black paper micarta. I assume neither is really the best thing to tap threads into for screws, so I guess I would have to use pins to hold the scales on in this case. Rather than using peening, I would epoxy and pin like I do on fixed blades. Is this a good idea, or does it have drawbacks? Of the three methods I mentioned, which would be the best one to use?
Thanks in advance...
My Knife & Sheath Pages:
http://www.geocities.com/CollegePark/Lab/1298/frames.html
Palmer College of Chiropractic
Sheath Makers Referral Directory
agocs_s@dd.palmer.edu
Madpoet (Mel Sorg, Jr.) Tribute page:
http://www.geocities.com/CollegePark/Lab/1298/madpoet/main.html
Chiro,
Are you still planning on using liners? If so you can offset the screws on one side from the screws on the other, drill clearance holes in the spacer, drill 2 tapped holes and 2 clearance holes in each liner, screw the screws into the liner on the side opposite the screw head, and have threads in steel, rather than the spacer material.
If this is un-clear, email me and I'll create a JPEG picture to illustrate.
Good luck
Bob Couture
