I understand that it's too inefficient (from a cost point) for Spyderco to flat-grind their H-1 blades. If I have it sent to Tom Krein (obviously a professional) for such modification, would that void the warranty?
I've read about work-hardening and while I understand that, for example, a backhoe's teeth are work hardened, I'm still confused. The backhoe's teeth are rammed into concrete, producing heat and friction. This hardens them even further. Got it. But the heat and friction from running my knife blade on a ceramic sharpener is high enough to alter the heat treat?
Lastly, I have a warranty question. As an example, I'll use the FRN Dragonfly. Let's say I didn't like the blade shape so I threw it on a belt sander and now it's a tanto. I clearly voided the warranty by doing this. But let's say a warranty issue comes up that's not related to the blade modification; the permanently-mounted pocket clip broke off. Is the pocket clip covered under warranty because it had nothing to do with the tanto mod, or did I ruin the entire warranty with one dumb mod? (No, didn't happen, just asking.)
