So I collected a few questions about approaches for edge maintenance. Following some recommended videos, I'm using this sharpening process:
- De-stress the edge
- Shape the secondary bevel
- Apex and refine (I do this by creating a micro-bevel)
- How do you decide when you need to shape the secondary bevel, versus skipping it and going straight to apexing? I don't have any kind of optics to examine the edge up close, but if there's no visual damage to the secondary bevel, is it legit to skip the shaping step? I assume that as time goes by and you resharpen a blade enough times, even without visual damage to the secondary bevel, you'll take enough metal off thru repeated sharpenings of the micro-bevel, so you'd need to shape and recreate the secondary bevel.
- Does it make sense to always de-stress the edge, every time you sharpen, at least in part so you have a visual indicator to know when you've successfully apexed the edge (no light reflects on it)?
- In a minimalist sharpening approach where you use only 1 or 2 grits for sharpening, and the goal is to quickly get a shaving sharp functional edge without concern for polish, does it still make sense to strop after you apex, to get best edge refinement?
- If I strop and want to keep it simple and do it dry, would it work to just throw a thin 1/8" piece of balsa, or a piece of printer paper, or a thin piece of cereal box cardboard on my stone, so that it has a hard backing? Or is the balsa still too soft?
