NJBillK
Custom Leather and Fixed Blade modifications.
- Mar 27, 2014
Quite a few folks are under the impression that D2 takes a decent edge at best, but holds it for a Very long time. I can get my D2 knives shaving sharp without much issue.
Where the conflict starts is, a lot of folks will say that D2 needs a fairly thick edge to support the large carbides. The knives that I have in D2 are fixed blades and are all over .035 BTE.
1) How is this not the case with D2 traditional knives?
- A lot of Queen, Schatt & Morgan, and other brands use D2 for their knives, but many are brought down below .020 BTE and they do not experience edge failure.
2) Is this due to their expected lighter use?
3) Keeping in mind that the majority of these knives are slip joint in design, and the resulting lighter use; could it be that the alloy is essentially being pushed closer to its failure threshold, but only survives due to the strength of the alloy?
4) Is it likely that the manufacturers are betting on the steel being "strong enough" based on 90%+ of the uses being on the lighter end of the EDC spectrum (opening mail, boxes, trimming nails), as opposed to heavy side loading from whittling it poor technique, cutting knotty wood, or other stresses that overcome the lowered threshold duet the thinner cross sectional edge profile?
I know it isn't likely that anyone would be able to answer all of these aside from some folks that have a particular type of education, or work experience. (Maybe
mete
would be kind to chime in?)
Also, if anyone has some solid ideas, answers, leads or information that may be willing to share, I am all ears.
That being said, if anyone has had a D2 traditional fail on them, or survive usage that they were expecting damage from, could weigh in, I would appreciate it.
Thanks folks.
Thanks folks.
