- Jan 2, 2011
I have decided that I want to make a slip joint or maybe a frame lock. I am just going to do it and start with a slip joint so I can carry a pocket knife of my own making. But I need some clarification on some aspects of them.
I want to use a stainless steel for the blade. Why not use the same type of steel for the spring...
1) I hear that 45 RC is a good spring hardness after fully hardening the spring. When I try to look for temper temps for those numbers I don't find suggested temps. I am thinking about using CTS-XHP, AEB-L. But I am open to other suggestions maybe CPM-154cm.
2) From what I can gather, the pivot pin is not glued in or anything?
3) I saw Steve Culver's tutorial about making a slip joint and he uses a Ruple Dial. Is that some special dial to buy or make? Can it be done without the Ruple Dial?
4) What are the traditional blade thicknesses and liner thicknesses for slip joints?
-Brian-
-Brian-
