Brian.Evans
Registered Member
- Aug 20, 2011
Upon the advice of Don Hanson III, I'm going to make a bunch of paring knives before I do make anything else. I'm envisioning a 3" blade paring and a 4 1/2-5" kitchen utility, basically the same knife with a slightly longer blade. I'm looking at making about 20-30 of these blades.
I guess I need a bit of direction. I'd like these to be as well made as I can. I'm going to be using 1/16" 1095 stock from Aldo. I have toyed with several thoughts in my head, and I'll just list them, because that is how my brain seems to work.
1. I'd really like to work on my grind lines and plunges, but I'm not sure if proper paring knives should have them? I'm torn I guess. Should they be ground straight through, like a Japanese blade? I've seen both ways.
2. I'm planning on profiling, drilling for pins, and then drilling lightening holes before HT. Not grinding bevels before HT seems like a no brainer on 1/16" oil hardening steel.
3. Stuck on scale material. I'm planning on making several of these to practice my grinding, so I'd like to vary the scale material within a certain range. Any suggestions? I'm thinking 416 SS pins, just because it seems nickel silver is verboten around food according to some foodie forums, but ??? Anyway, back to handle material. I'm assuming an oily wood like cocobolo would work, but I'd like to stick with synthetics this round. Something like all linen or paper micartas in different colors.
4. I'm really going to shoot for clean on these. Clean belt finishes, clean handles, nice pins, etc.
I really like this knife:
http://www.bladeforums.com/forums/showthread.php/1062145-Ironwood-Paring-Knife
And of course this one:
http://www.bladeforums.com/forums/showthread.php/1062057-Black-G10-Paring-Knife-Davison-SOLD
http://www.bladeforums.com/forums/showthread.php/1026772-Green-Micarta-Paring-Knife
Ok, I think that's it. I'm pretty tired, so if anything up there sounds weird, I'm blaming it on that. I'll fix it in the morning.
