A fine knife by the new kami, Anil.
Howard Wallace
Moderator
Yangdu sent me out knife #4 from Anil’s offerings in this thread.
I like small knives with offset blades. The offset serves as a guard to prevent a hand from slipping up onto a sharp edge, and it also permits cutting against a board or a log without the hand getting in the way. Many kitchen knives have this feature. I’ve never discussed my preference with Yangdu. Yet she sent me the one knife of all the 4 that had the most pronounced offset. I wonder how she does that.
I gathered up some of the other knives I use that have offset handles. In the picture below you will see Anil’s knife on the bottom. Next are 2 knives forged from files by members of the Larios family in Sayula, Mexico a number of years ago. The one with the red handle has seen years of use in my kitchen, while the slightly thicker one with the maple handle gets field use. On top is a Boker with a blade of 440C that I use for saltwater fishing. It has slit the gills of many a fish, and done its share of gutting and cutting bait too.
Also for comparison purposes is a new Carvel Hall cleaver I picked up at Goodwill for $3. It was made in Japan, and has the word “CLEVER” deeply stamped into the wood handle. It’s about the same size and weight as the Anil knife. The cleaver blade, while wider, is also thinner than Anil’s knife. For chopping weight, they have a similar feel. The Anil knife could address cleaver tasks. While perhaps not as efficient as the cleaver in its specialized role, it will do.
A few minutes after this picture was taken I used the Anil knife to whittle the misspelling off of the cleaver handle.
The Anil knife snaps solidly into its sheath, and is well retained. Here is a shot of all the sheaths lined up. Anil’s sheath is one of the smallest, although his knife is the largest. It is a nice carrying package.
The knife had a good edge on it right out of the box, so I used it as it came for a little vegetable cutting. On onions, my first try sprung the onions apart due to the thickness of the blade. After that, I held both sides of the onions and it wasn’t a problem. When comparing ease of cutting, the thin bladed Larios was the easiest, but all the others including Anil's were about the same. All were quite serviceable for meal preparation.
Over the next few days I used it for meat cutting and kitchen chores, and even took it out to the deck to harvest some of my heritage multiplier onions. It cut down the large stalks as seen in this picture. Note the patina naturally developing on the blade.
These onions produce little bulbs on the top of the stalks, which can be planted. I used the Anil knife like a trowel to help me plant a number of the bulbs. Rough work for a knife, but I felt bad just giving this big thick knife sissy work.
It worked fine as a trowel, and a couple of strokes on a sharpmaker brought the edge back even better than before. The edge holding is fine. A few days later I gave the knife a couple of swipes over the work-sharp with a coarse grit belt, just to see how it would do. It produced a nice toothy edge that was excellent for cutting meat.
I read how Karda had lovingly spent some quality time with sandpaper to bring out the beauty of the handle. I did notice some angular edges on the wood handle of mine, so I went to get some coarse sandpaper. 2 minutes later I had knocked off the angular edges. (I think the knives pray they will go to Karda’s place rather than mine!) Then I put on a bit of food-grade oil I use for my butcher block. The handle will evolve. I expect in a few years it will look similar to the maple handled Larios in the photos above.
I no longer heat with wood, so the need to split kindling is no longer present. I’ve batted enough knives through wood to know that this stout blade profile would have no problem with chopping, splitting and battoning.
Anil has produced a fine, field grade knife. A good outfitter would be proud to offer this to his customers, knowing that it could be depended on as a solid, reliable knife, capable of not only kitchen type chores, but also chopping, battoning, or digging should the need arise.
Great Review Howard!
All I did to mine is well round the edges and end with 60g paper and then fine sanded it with 120g, after that I put about 8 coats of tru-oil gunstock finish on it to bring out the beautiful flame pattern in the wood and make it so it wouldn't get stained all up with use. That's the great thing about tru-oil... it's tough and easy to touch up or refinish.
Howard:
"Also for comparison purposes is a new Carvel Hall cleaver I picked up at Goodwill for $3. It was made in Japan, and has the word “CLEVER” deeply stamped into the wood handle.... I used the Anil knife to whittle the misspelling off of the cleaver handle."
Aargh! You ruined a one-of-a-kind cleaver. That might be (might have been) the only cleaver in the world with "clever" stamped into the handle. Like some of those rare postage stamps that are misprinted and therefore worth thousands to collectors.
Maybe you can use the Anil knife to carve "clever" back on the other side of the handle, to make it collectible again. :)
Apart from that, a superb review. Makes me want to get one. The Anil knife, not the clever cleaver.
-- Dave
This seems like as good a place as any to praise Anil instead of starting a whole new thread:D
I too have been using the R-10 heavily for the last several weeks. As a matter of fact, I feel like I should apologize for my absence from the forum. As a contractor working in the swimming pool industry, the end of April through mid June is a brutal time for me to get any free time.
In short, I absolutely adore this knife. I decided that since the price was right and that Anil had obviously crafted this blade to be a heavy duty user that I was going to use it extensively for every chore I could think of over several weeks. It was VERY impressive.
Like Karda, the first and only thing I have really done to the knife to modify it was to give the polished finish a brushed mat. I just stropped it on a sanding sponge to satin it up a bit. I also gave the beautiful maple handle two sandings and then a long overnight soak in boiled linseed oil. Finally, I dressed it up with just a hint of sponge on wood staining to make sure I protected the wood as I was going to really put this knife into some yucky stuff:D
Here's a list of just some of things I can REMEMBER doing with my R-10 knife:
  • I split flavor wood for the smoker
  • I cut the old vinyl liner out of pool
  • I cut in the return and skimmer fittings in the new liner
  • I opened no less than 40 heavy plastic bags of salt
  • I shaved burs off of PVC pipe before gluing it together
  • I dug mud out of my boots before getting into my new truck
  • I cut off some mint sprigs for a well earned mint julep
  • I opened 12 bags of mulch
  • I opened 14 bags of top soil
  • I used it as a pointer to show my daughter how the ants were carrying food back to their next
  • I pried open 4 paint cans (carefully)
  • I prepped a whole dinner consisting of steak, diced potatoes, and grilled asparagus (yes, I had washed the knife really, really, REALLY well:D)
  • I've opened and broken down about 40 boxes of product at my office
During of all of that, the only thing I did was to buff off a bit of rust when I had to leave it a little wet, take it down an Arkansas stone a few passes, and then hit with a strop. It pops hair allllll the way down the edge. I did craft a quick and dirty high and tight sheath for my belt where the edge faces out (basically a left handed sheath). I did this because I found that the natural curve of the handle really lent itself to a dagger grip where I could draw it, give a long sweeping cut across material (like a plastic bag), and then sheath it in one motion. It made cutting and sheathing much easier as I didn't have to hike my shoulder up to drop it back in. It was basically designed around the idea that I knew I was going to cutting multiple bags open with the blade.
I am VERY impressed with Anil's work. This kami can craft a blade. It's a great all around blade. In addition to using it as a heavy duty work knife, I've also felt more than comfortable wearing it as a back up SD weapon. 5" of pointy and razor sharp steel held in a dagger grip is nothing sneeze at. Riding high and tight, you hardly notice the knife. If anything, the handle is almost TOO beautiful as your eyes are drawn right to it on my belt:D
Here's a fast pic with an FN for scale as this and the R-10 are what are on my hip today. Potent medicine for sure.
I too have been using mine for a camping trip and for some hiking. Love it. It is probably on of the best knifes I have picked up and I can see that it will be getting a ton of use this summer. Mine had the smaller rounded handle on it and it just fits the hand perfectly. Could not ask for anything better to take on hikes. Everybody how saw it on today's hike were very impressed with it
... I did craft a quick and dirty high and tight sheath for my belt where the edge faces out (basically a left handed sheath). I did this because I found that the natural curve of the handle really lent itself to a dagger grip where I could draw it, give a long sweeping cut across material (like a plastic bag), and then sheath it in one motion. It made cutting and sheathing much easier as I didn't have to hike my shoulder up to drop it back in. It was basically designed around the idea that I knew I was going to cutting multiple bags open with the blade.
You can reverse the sheath in the frog for a quick and dirty left hander. Of course the seam in the leather shows if you do this. Perhaps not as elegant as the one you made and forgot to show us, but it works.
Take care with those efficient knife motions. They can freak some people out. We don't want to be taking up a forum collection to bail you out of the hoosegow. ;)
Great review and pix, thank you Howard
The Anil knife left my possession today.
My son and his fiancé were up for a visit. He’s a grad student on a NSF fellowship, studying biology and neuroscience. He was telling me he does most of his food prep with the pocketknife I gave him years ago when he left home. Summers he runs a vole ranch (for his research) in Indiana. I imagine him herding them on vole drives, and roping them with tiny little lassos.
I know he actually does stuff like digging postholes, stringing raptor netting, and other duties related to maintaining enclosures. Anyways, the lad needs a knife so I gave it to him.
I prepped a meal for them with the Anil knife this morning, touched it up on the Work Sharp, and sent it off to a new life. It sounds like it will be the only fixed blade in the kitchen, and may get a bit of field work also. My son agreed to write on his experiences with the knife at some point in the future, so stay tuned.
Very cool gift, I bet he thinks of you every time it's used.
And of Yangdu and the kamis also.
It must be a decade or more ago now that my son was able to catch Yangdu in the airport and interview her for a school project. Was it Jr. High school? It was an eye-opener for him, and he got to hear some "uphill both ways" stories that were more believable than most. He has a pretty good idea of the stories behind the knives.
