A good stout blade with some nit-picky requirements
I'm looking for yet another blade but with time I have developed certain tastes, yet can't find to find a good blade but can't seem to find one that fits all my qualifications. Now here is the run down of what I want:
4-5" blade, would prefer 4.5" at a minimum but would dip below if need be
Not hollow or convex ground. Either Scandinavian, Sabre, or FFG
Wider blade, No exact measurement here but I like a fairly wide (not cleaver wide, but stocky) blade
Chunky handles, I like something wide enough to get a solid grip on
Swept belly, with some sort of strait portion. I'd like a blade with some sort of belly, but not all belly like a trailing point
Fairly fine tip I like something more precise then a kephart but not a dagger tip
No choil. Nuff said
A fairly small space between the edge and my hand, I prefer an edge that starts fairly close to my hand for more control so small/no guard and as small a ricasso possible
And the most nit-picky of all; Steel choice. I am an admitted steel snob and I prefer carbon steels, something high quality. There are several stainless options that would be suitable as well. NONE of the following: 420, 440X 1075, Xcr13mov, AUS-8, ect.
Also, a good sheath from the factory would be extremely preferable.
Now, the kicker: I'd really like to keep this under $150 and less is more for price (tight budget)
Well, Whattya got?
I had a pair of Battlehorse Renegade's made with extra liners to fill out the handles. They come very close to what you are specifying.......
I realize It's a tall order but the Renegade is just a little dainty
Have you actually handled a Renegade? I would use a bunch of words to describe them, but "dainty" sure is not one of them....(I'm not trying to be argumentative here. I had thought that they were smaller than they are myself based upon the specs given on the BHK site. However, when I got my hands on one, it was beefier than I had anticipated. It'll handle most anything that my Bravo I's can do....I see 'em more like a shorter version of the Scout Platoon.)
I'm familiar with the type however I'm pretty set in my ways in terms of blade length. Thank you for the suggestion
Another idea is a G.E. Chen Duty Fixed Blade ( now without a choil ) in 3V G. E. @ $175.00 ......It may be slighter shorter in blade length though definitely check it out
Overall Length 8.85"
Blade Length 4.13"
Sharpened Length 3.94"
Blade Thickness 0.17"
Blade Material CPM-3V Powder Steel
Steel Type Carbon
Blade Rockwell 58-59 HRC
Handle Thickness 0.86"
Handle Material Micarta
Weight 6.60 oz.
Sheath Kydex
Sheath Weight 2.35 oz.
Country of Manufacture China
I would check out Battle Horse too. My Field crafter sounds alot like what you are looking for and I got it for $140 shipped!
Blade Length 4.13"
Steel Type Carbon
Weight 6.60 oz.
Sheath Kydex
I like it but finding it seems to be a challenge
Sounds like an Esee 5 would fit the bill: big handle, sabre grind, no choil. Not sure how you feel about 1095, but it's a solid knife and definitely fits your price range.
Oh I love my ESEE 5, but the thing is a brick. I do a lot of food work and the ESEE 5 can't do that at all
Mmmm maybe check out the Southern Grind Jackal. A little over budget at 219.99, but you can currently get 15% off (Coupon Code: GRIND15)at USA Made Blade w/ free shipping, which brings it a little in more in line with the GE Chen Duty.
That one does look nice... I may have to stretch my budget. I'll keep it as an option
Might check out the Ritter RSK Mk2 or Mk3 fixed. Mk3 looks a bit closer to what you have asked for I think, does have a small sharpening notch tho.
