Mistwalker
- Dec 22, 2007
The green is back completely now, and spring will soon give way to summer. I needed to capture some images for a project I am working on, and so I thought I would share some shots that go into herb lore and some other images of spring in a temperate rain forest.
One of the plants I was seeking was Solomon's Seal. It is a rather unique plant that stands out from most of the others it is commonly found growing with.
The flowers hang below the arched plant, but sometimes the bees will help you find it.
The flowers soon become berries. Do not eat them, they are toxic
It's the root I am after. Minced and crushed, and made into a poultice it is used as an astringent to slow bleeding and help heal minor wounds.
It helps to have something to dig with, but I didn't bring anything. So...I had to whittle a digging stick
The roots can be pretty long, so if you cut it on a node before the end, another plant will sprout from that node.
Then cut it behind a node just away from the plant stem and you have a section of the root.
If you then replant the root with the stem, if all goes well, next season you will have two plants from one., thus sustaining growth of a medicinal herb.
The garlic is also up good. I love garlic, it's good for your heart, and helps keep the mosquitoes at bay as well. This is another you usually have to dig. Pulling usually just breaks the stem.
Lots of sassafras here, makes a nice tea. It's pretty easy to identify, with a mix of single, tri-lobe, and mitten shaped leaves.
The poison ivy is flowering and will soon start producing berries.
A lot of color after the lifelessness of winter.
A huge insect population here in the warm months
Looking forward to blackberry season!
These guys are usually pretty chilled out, but I'd advise not making them feel like they need to call for reinforcements
I go hiking by myself a lot, but with all of the eyes in the forest, I never feel lonely.
