A little respect
Hey guys!
Just thought that I'd take a minute to emphasize the importance of safety and common sense when working with power tools. This weekend, I started making a new handle for my AK. I made up a few blanks of oak to work with , and cut them to approximately the length that I needed. The next task was to get rid of the waste wood to bring the wood to the approximate diameter and shape desired for my handle. Many different tools can be used for this, some safe, some not so safe. I chose the latter of the two... A 12" compound miter saw is a very useful tool. It is designed for crosscutting and mitering wood. It is very good at cutting through even really hard wood, with very smooth cuts. Usually to take a piece of wood down to rough size, I would use my radial arm saw with a sanding drum on it, or else use it as a planer of sorts. My radial arm saw is temporarily out of commission (too much junk on it!), so I figured, "Hey, I can use the old miter saw, I'll just be careful...". BAD IDEA!!!! I was using the saw as a planer/gouge to form the rough outline of the handle. It was working very well, and I was just about done with the roughing in stage. I was trying to get close to the pommel of the handle, to smooth it out and take it down a little more, when the wood caught in the blade. The binding didn't take the wood out of my hand, but did manage to pull my left thumb into the blade. I was VERY BLESSED, I just got a nick on the tip of my thumb about a blade tooth wide (1/4") by about 1/2 inch long, and about 1/8 to 1/4" deep. This is a very minor cut from a saw like this, it could have very easily taken the thumb clean off, and not missed a beat.
The moral of the story is this: use the right tool for the job, and BE CAREFUL! I was not seriously injured this time, but it could have been much worse. We get too comfortable with tools that we are familiar with, and forget sometimes, just how dangerous they are. Keep your digits in place, you might need them sometime!
Take it easy,
Rob
PS, the handle is coming along well, outside of a slight blood stain on it!
I'd rather sleep next to a Bush than be Gored!
Rob, you're absolutely right about the danger of getting too comfortable with our tools. I lost my little finger, right hand, while doing a bunch of ripping with my radial-arm saw -- because of the monotony of the work, I had fallen into a routine and had let my mind wander. All it took was a split-second of carelessness!
Rob, many thanks!
I've mentioned being careful in the shop before and I'm glad you brought the subject back to the fore. I have been very lucky. I almost lost my hand once and I can still remember the incident like it was yesterday. It happened more than 20 years ago when I was old enough to know better than to do what I did. No details, please! I am too embarrassed to post them.
Blessings from the computer shack in Reno.
Uncle Bill
Himalayan Imports Website
Khukuri FAQ
Himalayan Imports Archives (18,000+ posts)
Yes!!!
By all means be very careful!!!
If you lose your middle finger on either hand it will keep you from being able to emphasize your point doubly when in a heated discussion!!!!
Yvsa's poor attempt at humor this morning.
Seriously be very careful. Familiarity seems to breed carelessness. And I have done my share of stupid, careless mistakes as well and am very lucky to have all my digits as well as other parts of my anatomy.
>>>>---¥vsa---->®
"I would rather have a bottle in front of me than a frontal lobotomy."
........unknown, to me anyway........
Khukuri FAQ
Rob I use firewood to obtain a fairly board shaped piece and then profile it on my 18" scroll saw leaveing it a bit oversize all
over.
I have to take it slow and use a 9 tooth per inch blade and usually break a couple of them due to the wood not being perfectly flat and square.
I leave the wood long enough to have a handle to hang onto when using wood rasps and files to shape and round the actual khukuri handle.
I have made the khukuri handle's butt end out and bolster end out depending on whether I was going to use the scrolled butt cap or the original bolster.
When using both it is easier for me to do the butt end out, leaveing the bolster end oversize to finish after removeing the khukuri handle from the excess wood I used as a handle.
When I done the one for the as forged Chainpuri blade I had a piece that was flat and square on the 4 sides and bottom. I still left excess on the bolster end in order to get the shape I wanted on the butt correctly finished.
The flat and square piece made it much easier to cut to shape.
>>>>---¥vsa---->®
Khukuri FAQ
