You guys are a bad influence, I ordered a Victorian longleaf from IMA, with the hand select option, here are some pics and description. It arrived heavily wrapped in layers of plastic and cosmoline. The handle wood seems rather fragile, there was a loose chunk of wood which broke off during shipment, I found it floating around in the plastic. Hopefully I can glue it back. I wonder if there is some method of stabilizing aged, fragile wood of this type. Anyone work for a museum? The wood also has cosmoline all over it.
blade length: 15" OAL: 19.25"
max spine thickness 12mm at the bolster
max blade width 67mm at the belly
wt approx 700g / 26 oz
Handle has many large chips around the edges.
The edge is very worn and dull over the sweet spot and tip.
The inscription on the spine seems to say Shree 3 Chandra, Na ?Sa I cannot figure out the rest of it.
