- Sep 14, 2003
Not having the same writing skills as either Codger of Robert I still felt the need to add a review to the set. So... here ya go! Pictures at the end.
LB7 TaylorLLC
I was recently sent a newly manufactured imported version of a venerable Imperial Schrade LB7 Bear Paw with a Sheath for examination and review, and the box does resemble a real Schrade box. The top of the box has the image of an American flag on it to help confuse the buyer. The side of the box does have the importers name on it, Taylor Brands, LLC. Only on the barcode end-flap does the word "China" appear, and in the product I.D. Title. "SCHRADE LB7 CHINA". The box itself is corrugated pasteboard.
Like the previous reviews the LB7 came shipped in its sheath. The difference is the knife was wrapped in a piece of waxed brown paper.
The instruction sheet was the same as that of the 7OT and 15OT, written in Spanish, English and French printed on threefold paper.
Extracting and opening the knife there is a bit of roughness to the blade swing almost having a ½ stop, followed by a great click as the lock engages when the knife is fully opened. Closing the blade required a lot of pressure on the back of the spring. I asked for my wife to attempt to close the knife. She was unable to squeeze the lock with enough strength to unlock the knife and swing the blade close. Some oil and use may loosen the blade and lock some but there is a design difference that causes me concern. The center backspring pin has been moved towards the back of the knife by just over ½ which shortens the fulcrum length which in turn causes more downward pressure to be needed to release the lock. The backspring is very strong and it left a mark on my fingers when exercising the opening and closing of the knife. There is no blade movement when open. Some side to side movement when closed but no difference than my other LB7s
Just the Facts.
Overall:
The weight is 7.5oz where the originals are heavier at 7.8-8.0oz.
Its also 1/16" thinner. 9/16 verses 8/16.
The blade is 1/8 shorter 3 9/16 verses 3 11/16
The Center pin has been moved back toward butt of knife by just over ½
All the visible pins brass and are thinner that the original.
The bolsters have sharp angles, not rounded at edges front and read and the finish is brushed brass.
There is no pivot pin showing through front bolster.
The scales are wood with a rich red-ish stain in a flat-satin finish. Finish is just a bit rough with a bite to the surface of the pins and edge of bolster/scale when running fingers across. Along the backspring side the wood does not come up flush to the bolsters. Blade is sharp but not quite hair popping sharp right out of the box.
The blade grind line starts lower towards the edge. The profile of the blade is about the same with the kick and swedge being almost exact. The Choil is a little longer.
On the Mark Side: The nail nick is same size as later model LB7 where the earlier models had a smaller nick. The blades are stamped:
Uncle Henry over SCHRADE on tang.
SCHRADE SUPER-SHARP embossed across grid line.
(Original has either Uncle Henry over SCHRADE+ over LB7 U.S.A. or same without the Uncle Henry)
Pile side:
There is a huge LB7 stamp on tang compared to nothing stamped on the original.
There is First Production Run and the China Schrade trademark across grind line.
Like the 6OTc the interior liner brass is unfinished except strangely for 1 in the center on both sides. This may also explain some of the rough blade movement.
Sheath: Extinct Naugahide reconstituted leather. Thin, flexible. Vinyl feeling. Schrade stamp on the flap and snap. Waterproof for a day.
Conclusion: IMHO:
They almost made a decent knife. If a final grinding pass were made, this knife needed a little extra. I like the hidden front pin. The difficult operation of the lock and the exterior roughness of the finish causes this knife to be a non SCHRADE.
Its a shame what is being sent as a leather sheath. I think the nylon sheath that comes with the 6OTc would give better use. Quick giveaways that you have a TLLS LB7: the center pin in the bolster, grind line and of course the tang stamps
LB7 TaylorLLC
Just the Facts.
Overall:
Pile side:
Conclusion: IMHO:
