- Mar 19, 2007
I got in the mail today - a little fun blade for myself as I wait for my BRKT.
https://www.kabar.com/product_detai...&categoryId=2,7&categoryName=Hunting/Sporting
A Ka-bar hunter:
AUS 6 Steel.
Blade 4 inches long
0.1000 width at the hilt and .0500 at the tip (due to a clip blade).
0.668 tall
Hollow Grind (very slight due to width of blade.
Overall length 8 and 1/8th inch
Aluminum butt cap and Brass guard. Leather washer handle with colored spacers.
Handle width at the palm swell 0.824 with finger grooves.
3.574 usable handle length.
The sheath is made of leather. It looks CHEESY in the photo's but in reality isn't too bad. I need to stitch the handle wrap so it does not move - but other than that - it is a serviceable little sheath.
The fit and finish of the blade and handle was surprisingly very good. Mirror polish on everything and it was a VERY tight little knife! The Guard had a few rough spots where it butted up against the spacers and you can see where the stick tang begins slightly by looking closely to where it joins with the guard - but other than that - the fit and finish is very nice indeed.
This little sucker is a fun knife! I sharpened it using a simple Lansky kit (I wanted it to have the blade geometry it came with) and set the bevel at 25 degrees. It was fairly sharp out of the box - but it wipes hair away now after I cleaned up the grind (which was respectable) and took it to a 2000 grit stone. I stropped it on jean material, polished it again, then stropped it lightly.
It fits great in my hand. It is a suprisingly small knife - but does not feel uncomfortable in my hand. The butt cap makes all the difference. I quickly took a branch (medium hard wood) and batoned it in half, cleaned up the batoning - drilled a hole (it drills like a beast) and cut a notch for my fire board. I made a spindle and had fire in no time.
The knife looked no worse for the wear and was not dulled.
For 25 - 30 bucks - I don't think you can really go wrong with this!
I will take pics soon.
TF
A Ka-bar hunter:
AUS 6 Steel.
Blade 4 inches long
0.668 tall
TF
