A new product for you gun folks!
As you guys know, shooting and training is a big part of Hinderer Knives. Rick and I were after a cleaning kit that would cover a wide range of guns in one set up, versus dragging numerous kits and rods around. Well we stumbled over the Otis 85211 and found just what we were looking for in a nice compact package. We've been using these kits since the SHOT show and have been extremely pleased with their performance, so we thought it would be a good idea to add them to our product line up. These are just the beginning, you will see other firearms and outdoor related products from us in the future.
If you guys are interested, they will be on the site in a few days!
OTIS Law Enforcement Deluxe Cleaning System #85211
Cleans
- 5.56 & 7.62 Rifles
- 9mm – 45ACP Pistols
- 12 gauge Shotguns
The 85211® tool set is designed to clean and maintain your long guns, pistols and sub guns 9MM through .45 caliber, .223 Cal./5.56MM & .308 Cal./7.62MM rifles, and the Otis Patch Savers® give you 360 degree coverage in your 12 gauge shotgun bores as well. This weapons maintenance system provides you the necessary tools to completely break down and clean some of the most critical parts of your firearm. The Memory-Flex® cleaning rods, solid brass slotted tips, 100% cotton cleaning patches, bore brushes, and an all-in-one cleaner, lubricant, and preservative allow you to quickly clean the receiver, chamber, neck and bore. Also with these components, you can easily strip the copper, carbon and other residue from in the barrel. The brass obstruction removers are used to knock out bore obstructions and stuck cases. The components from the brass scraper tool set are specifically designed to clean the hard to reach areas of your firearm. The brass scraper helps to clean carbon deposits from flat surfaces such as the bolt face and rails. The handy picks are engineered to clean the locking lugs, while the pin punch can be used to remove pins from any firearm held together with a pin system. The end brush is used to remove carbon and to lubricate the slides. The male and female rod handles can attach to any of the brass scraper components to increase their length. Everything is neatly packed in an 11oz., pocket size soft-pack case marked with the Hinderer Knives Logo.
I have one and they are great. I have one gun that would require a long break down to clean, if it were'nt for this pull through kit.
