- Jul 23, 2015
I have placed an order for a sheet of 15N20 in .140" thickness. It's coming to me at the shop, so I will can cut blades by angle grinder, and heat treatment by Andy Pomorski. This will allow faster turnaround than my stainless blades. I'll be consulting with my customers who have 15N20 from me already to see if and how we might be able to tweak the tempering cycles.
15N20 is a simple, fine grained, tough alloy, capable of high edge stability at thin geometries. I believe it has higher corrosion resistance and wear resistance than 8670, but less toughness (it is still a tough alloy mind you; I tested a 3/32" 15N20 Barax machete and it was a really heavy hitter for its thinness, weight, and relatively neutral balance).
This steel has proven itself to me in utility roles, food prep and hard use such as machetes. In this thickness it will make great blade of just about any size, especially geared toward harder use with thin edges.
If interested, please email or PM me to discuss what knife you'd like made. I will not take deposits on these, they will be right of first refusal. This allows me the leeway to put them on hold when blades come back from heat treatment that are for customers who have already put a deposit down. There are a number of those outstanding yet, in AEB-L and MagnaCut.
Blades
My handmade blank features can include, but are not limited to, the following options:
20 LPI fine jimping
Extra material removal in the tang to reduce weight
Radiused spines/ricasso edges
Grinds will be flat, flat-vex or convex
Can be single or double edge, tanto, swedged, etc.
Fine scotchbrite satin finish
Handles
Canvas Micarta in black or natural, including .060" canvas liners of either color (new to the shop), as well as canvas pins of either color (also new to the shop.
I will likely be making one for myself (as usual!) with double liners of each color over scales of one of the two color and pins of the other color, having been inspired by the look of knives from Fiddleback forge.
Other materials include Suretouch, including all black Suretouch (new to the shop), G10, and whatever surprises or goodies will be included in the 11 lb. end cut box I just purchased.
Oh and Green Burlap Micarta.
Handle finishes include flat, contoured, radiused, dremel textured, or any feasible combination thereof.
Pin materials include canvas micarta pins in black and natural, brass tubes, and carbon fiber tubes.
Sheaths
Will be black Boltaron, taco by default, pancake also available.
Blades
20 LPI fine jimping
Handles
Sheaths
