Hello All!
This is my first post on this forum, and before I get on to my question, I want to take a second and thank all the BladeForums contributors. I've learned so, so much over the years from reading your posts. Thank You!
So, I've been making knives for seven or eight years now. When I started, I would put my blades in the forge, wait for them to reach the "right" color, pull them out and quench them. Then I'd throw them in my oven (sometimes along with dinner
) and temper them. As I began learning more about metallurgy, I understood that I needed to upgrade my heat treating setup, so I built a PID controlled electric furnace. I'm working with larger knives now (mostly shortswords and long seaxes) and with harder to heat treat alloys and am planning on building a molten salt setup. I've done a lot of reading--including Kevin Cashen's sticky on the subject--but still have SO many questions!
First and foremost, I want to be safe. Most of my questions on the construction of salt pots have to do with safety. I was planning on buying a stainless steel pipe around ~30" long by 4"-6" wide, TiG welding it to a piece of plate (same alloy) and building a long, verticle, tube-like electric furnace out of refractory bricks, a steel frame and skin, hand wound resistance wire and a PID controller setup around it. Does this sound reasonable? One of my main questions is what alloy I should choose for the tube? Somebody once told me that 316L was the best choice, but I don't have any idea. Would 304 or 304L work? How about plain old 316? ...I really don't want to choose the wrong material and have it rupture on me because of heat stress... (BTW, I want to build high and low temp setups and a salt quench setup. And someday I want to build a carburizing setup lol)
Another concern is keeping my salts clean and neutral. First off, I have no idea how to do this (let alone how to test them), and secondly I am concerned that I wouldn't be able to maintain something that long and skinny...
Any thoughts, design critiques and suggestions you could offer would be greatly appreciated.
Cheers,
Tim Harbert
Cheers,
Tim Harbert
