- Oct 7, 1998
A recent thread about alloys containing varying amounts of carbide formers created a question in my mind.
There is in medicine a difference in which certain molecules will compete for a binding site; some will more avidly bind than others. For example, ethyl alcohol is used for methanol (wood alcohol) ingestions, as the ethyl alcohol will compete for the binding sites on alcohol dehydrogenase, and therefore prevent the methanol from binding, and thereby prevent the formation of the toxic compounds that can cause blindness.
My question is this: Is there an analagous situation with carbide formers? I know that C, Cr, and V will form carbides. However, is there a way to determine, from the chemical formula of an alloy, what the quantity of the various carbides will be? For example, if you have so much C, and so much Cr, and so much V, what must the proportions be in order to have enough free Cr to provide corrosion resistance?
The specific alloy which brought about my question is CPM420V, which has the following composition: C 2.2%, Cr 13%, V 9%, Mo 1%. Would this alloy be corrosion resistant?
I realize that there is enough Fe to make carbides of all the carbide formers, but this does not happen. Stainless steels depend on free Cr for corrosion resistance, hence not all Cr is bound up in carbides. On the other hand, there is one whopping lot of Fe which could be bound in carbides with all that C and V. Would this, then, make less Fe available for the Cr?
Any assistance in alleviating my confusion would be welcomed. Walt
[This message has been edited by Walt Welch (edited 04-18-2000).]
