a sharpened or serrated choil / sharpening notch
on my knives i like to have a small sharpening notch (which i believe is called a choil but Im not 100% sure if that is correct)
without the notch i have trouble sharpening it plus it also wears out my stones very fast by rounding the corners of them.
i use a plain edge knife and The problem is sometimes stuff can get hung up in the notch. Its not a huge problem now that ive gotten used to the notch being there but it is still something i would like to avoid happening.
the idea i had to help prevent this is to basically make the notch a single serration. If i can figure out a way to make the notch sharp then when something falls it, the sharp edge will cut it. this way i still have all the benefits of a sharpening notch while also preventing the downsides of one.
I just dont know how to go about sharpening it. I used a dremel to cut the notch originally going very slow and taking my time to prevent from heating the steel up to hot and messing with the temper/heat-treat. it took a while but i was able to do it without it getting even slightly warm.
I dont know if i should just use hand files or if i should use the dremel again.
I also dont know if i should sharpen both sides like a regular knife edge or if i should cut it like most serrations that have only one side sharpened with the other side flat.
i would love to hear what you all think about this idea and ANY advice about how i should go about doing this. I would prefer to pay someone more skilled in "knife-smithing" to do it but i have no idea how i would find someone who could do this for me
I have done this exact mod to several of my knives that have choils. I used a long diamond burr bit and ground it by hand. I did both sides but imagine one only would work better. I don't keep them razor sharp, just enough to prevent hanging up on loose materials. It works pretty well.
You can watch Youtube by Unit (ewerstruly on YT) on how to add the notch. Similar to what HeavyHanded recommended. I do that to all my EDC.
I use round diamond file, on both sides, at higher angle than sharpening angle.
I did this to a couple of work knives that see a lot of plastic wrap. Used to hang up in the sharpening choil, so I did this and it works beautifully! Thanks for the idea!
