Hi folks. I guess I was not very careful in how I was asking the question. I would like to know how to sharpen an edge that does not have a bevel and just comes to a sharp edge. This knife handle was made by his grandfather but I believe he said he had bought the knife with just the steel. I have never seen an edge like this without a bevel but did not want to screw it up by using my SM on it. It does have not have a bad edge but could use a sharpening. But then again I am picky.
Regards
Tar
Sounds like a 'zero grind' edge, i.e., sharp to the edge with no secondary bevel. Not a big deal; it's usually how I sharpen my own knives, for the most part. You could test for the edge angle by laying the blade flush to a flat & smooth surface, like a piece of plate glass. Look closely to see that the 'cheeks' of the apex just make contact with the surface. Based on the angle you see when that occurs, that would be where you'd set your hold to begin the sharpening passes on a stone. Easier still, edge-trailing or 'stropping' passes on something like wet/dry sandpaper on a hard surface are a simple way to maintain such an edge, again with the apex's 'cheeks' just flush to the abrasive.
The 'zero grind' could just be the result of what's essentially a shallow, low-angle convexing of the blade's primary grind, extending all the way to the cutting edge. This is basically what I've done with mine, either on stones (more recently) or with hard-backed sandpaper. If the blade was originally ground to a sharp edge on a belt grinder with a little bit of slack in the belt, that shallow convex would be a natural result of that process anyway.
Such an edge could also be easily maintained by just adding a small microbevel at a standard angle, such as that set by a device like a Sharpmaker.
I think you'd be right in first asking the owner though, to determine
exactly & specifically what he expects from a sharpening, or even if he wants it resharpened at all.
