- Jun 26, 2007
Hello all,
today I want to made a brief comparison of 3 knives: SAK Farmer, Enzo PK70 and GEC 748212. They are similar in dimensions (blade length 70-75mm, length OAL 160-170 mm) and all of them are slip-joint folders, but very different in all the rest, general shape, materials, grind. My comparison will took into consideration just two angles: cutting efficiency and handles comfort. Nothing high-tech or science, just my impressions of use.
The contenders:
Lets start.
First, the SAK Farmer: Ill made a stick-point and a simple notch on a very seasoned branch
Impressions: cutting efficiency is good, the handle isnt really comfortable.
Score:
- Cutting efficiency: 7,5/10
- Handle comfort: 7,0/10
Now, the Enzo PK70
Impressions: cutting efficiency is excellent, the handle its fairly comfortable.
Score:
- Cutting efficiency: 8,0/10
- Handle comfort: 7,5/10
Finally, the GEC 748212
Impressions: cutting efficiency is excellent, just a hair below the Enzo PK70, the handle its comfortable, and could be the most comfortable of the bunch if not for the second blade which impact on my palm.
Score:
Then, I cut some papers. As you may imagine, the knives are exactly as before the trials on the woods and cut the paper really well
Final score:
SAK Farmer: 14,5/20
Enzo PK70: 15,5/20
GEC 748212: 15,5/20
General notes:
Blades are different in terms of thickness, general shape, steels and grind. I found the Enzo PK70 and the GEC 741812 the best as a cutter. The SAK Farmer is a good cutter, but not at the same level of the others two
The handle of these knives are really different, both in shape and materials. About the comfort, I may say that is a tie for the Enzo PK70 and the GEC 741812. The GEC has a really comfortable handle, far above the Enzo, but the second blade impact on the palm, so at the end of the day its a tie. The SAK Farmer handle is fairly comfortable, but its too thin for my (big) hands, and the protruding small hole for the key-ring its very annoying on my palm.
Conclusions: my short test lacks a lot. I didnt tried the knives for different tasks, nor on several materials or fresh woods, i.e.. Anyway I use frequently all 3 these knives, so I may share my impressions of use whit some certainness, I guess.
First, all of 3 are very good knives, well made, robust, whit a fine fit and finish level, and reliable.
In terms of quality/cost ratio, the winner is doubtless the SAK Farmer: it cost some 35 euros (45USD), and is fairly comfortable and is a good cutter, to not to say about the saw, the reamer and the other tools.
In terms of general fit and finish + cutting efficiency + handle comfort, its a tie for me for the Enzo PK70 and the GEC 748212, to not to say about the fashion of these knives.
You may carry all the 3 knives day by day whit satisfaction, but if I need to classify them thereupon the best use, Id say: for a brief hiking on the woods, whit just a knife in your pocket, go to the SAK Farmer, it will be sufficient for all the small tasks you may imagine, and the other tools of the knife are a great addiction; if you want to stay light as possible and want a great cutter, go to the Enzo PK70; if you are looking for a great cutter, two different blades and a lot of charme, go to the GEC 748212.
Ciao,
Alfredo
The contenders:
Lets start.
Score:
Now, the Enzo PK70
Score:
Score:
Final score:
SAK Farmer: 14,5/20
Enzo PK70: 15,5/20
GEC 748212: 15,5/20
General notes:
Ciao,
Alfredo
