A Steel worth forging?
I was with another inspector today viewing a new pump station. There were cut-offs from 1 inch re-bar scattered around and I threw it in the truck. I spoke with the engineer and he pulled the specs on the re-bar, ASTM-615 Grade 60(.30-.40%C)(1.20-1.60%Mn)(.35-.60%Si)(.06%P)(.06%S)
Carbon-wise,that appears to be like a 1030 to 1040 steel,but with more Manganese and Silicon.Right? My chart only has composition limits for 1010-1020 and 1045.
Would this 1" re-bar forge into usable blades?
not for sure but i read in a book that if you grind the unknown piece on a bench grinder and you get alot of sparks its good knife material
if not you could always use them for practice or to make tools like tongs and stuff
It doesn't sound like good blade steel to me. I'd rather have something with at least .5% carbon. There's plenty of other stuff you could make from it though.
bladsmth said:
Not usable for blades.Would be fine for forge tools and decorative items.
I agree with Stacey. It's no good for knives but you can get it semi-hard by using Superquench. Do a search here and google. Superquench is a home made water quench recipe made just for getting low carbon steel hard and has had some limited sucess.
Gentlemen,
I thank you for your replies and information. No sense in putting a lot of time and effort into a blade that won't cut butter.
the worst you can do is have some fun banging on it. make a test peice and find out.
