A tale of two southards
Sonnydaze
A TALE OF TWO SOUTHARDS…
1) the AVO…a mid-tech by Brad Southard, and…
2) the Spyderco/Brad Southard collaboration. (the all-black model).
These two folders are nearly identical in closed length, (AVO: 4.50", Southard: 4.57")... although my photographic maneuvers do NOT always indicate this fact...
Note the similar blade-lengths: AVO: 3.36" tip to grip....Black Spyderco Southard: 3.44"
The large buying "seasons" of my life are about over, as I've owned and sold many excellent folders, in trying to find MY perfect EDC.
At times, I've owned multiples of the same model, without ever carrying one of them, and that is just plain foolish. I have finally discovered that I am NOT a collector, and have divested myself of the needless surplus.
The folder I bought a month ago: the Brad Southard AVO, was ~$500; the one I got in this month: black Spyderco Southard, was $210. Both are worth the cost, IMO. I'm currently carrying the $500 folder, and loving it.
Note that Brad Southard's site lists the AVO at $425, although the supply has been very limited and sporadic. I bought mine, as-NEW, from the Exchange, and of course paid a bit more. (The brown-G10 Spyderco Southard is readily available and cheaper than the all-black model.)
Brad Southard Avo features...(the first offering in his Performance Series)…
This folder is DEFINITELY a keeper. I have been carrying this folder daily since I received it last December. I have no plans to replace it with any other folder. So far, with my relatively casual blade uses, the knife has been very pleasing. IF I have ever owned a true Grail, then I suspect that this is it. I REALLY like this knife.
It is, obviously, a flipper. I have accepted that fact...and it "disappears." The flipper just happens to be there, and it works, quickly...very well indeed.
I could use a blade-stud or Spydie-hole just as easily, but this flipper is perfect, and suits me just fine.
The folder is rock-solid and centered...a beautiful example of the art.
The AVO has an unsharpened blade edge (choil) region which is large enough for me to get adequate index finger forward-control without danger...or to just hold it in the "standard" condition...
The first time I opened and closed this new knife, I got blooded immediately with this blade; barely felt it going by...and then there was a drop of blood on my index finger. It just floats thru 0.002"-thick Yellow Pages...it is the sharpest blade that I've had by far.
Some of the features and dimensions of the AVO are:
Carson Flipper with CTS-B75p (bg-42) blade-steel, stonewashed finish. Brad has also made a small number of blades, using PSF-27 steel.
Titanium frame lock, titanium Hinderer over-travel stop, titanium standoffs and clip.
Stainless hardware
Ball bearing pivot and ceramic detent ball for the smoothest and fastest action.
grip thkness: 0.460"
blade thkness: 0.140" (identical to the Umnumzaan and Sebenza 25)
0.024" behind the edge
3.33" blade (tip to grip)
4.5" grip length
Very comfy in my hand.. Rock-solid, no-stick goodness...This is NICE!
________________________________________________________________________
The Spyderco Southard collaboration, all-black model C156GBBK
length overall 7.96" (202 mm) blade length 3.46" (88 mm) blade steel CTS 204P
length closed 4.50" (114 mm) cutting edge 3.46" (88 mm) weight 4.1 oz (116 g)
blade thickness 0.157" (4.0 mm) handle material G-10
It is very similar to the Southard AVO mid-tech, other than the AVO is a smaller, thinner version of this Spyderco folder.
The black Southard grip thickness is 0.525”…thicker than the AVO, given the G10 scale and thick titanium liner on one side.
The blade-steel is thicker, at 0.157”, and of the excellent CTS 204P, but also 0.024" behind the edge.
The “black” coating on this model is titanium carbo-nitride. It coats the blade as well as the grips on this folder.
Here is a Spyderco link to this black model…
http://www.spyderco.com/catalog/details.php?product=885
I have owned several of Spyderco’s first flipper, the model in brown G10. I purchased two of these, NIB, admired them and sold them. The third brown one, NIB, I gave to one college-age grand-daughter last September, and it was then that I finally developed a real interest in this folder. And…I do seem to like the black color of knives, in general, and so jumped at the chance to buy one…ANIB, on the Exchange.
Okay, so I have both of these folders.
The black Southard (and the brown) have a slightly thicker grip. Also, a thicker blade-steel. In addition, arguably a more refined blade-steel.
Which should I choose?
I chose the AVO. It rides easily in my pocket; a great knife with a good blade, light weight, a classy look, greats ergos, and I’m happy with it. Certainly, it can be argued that I could buy several Spyderco Southards for the price of one AVO, but that would make this entire discussion one of finance rather than of one involving personal choice.
Now, the black Southard? I love that one too, but am not likely to ever carry it, unless I am planning a trip to the woods. It is, perhaps, a better steel; it will likely hold an edge longer, and the thicker blade of 204P will likely hold up better to abuse when camping, possible batoning, splitting firewood.
The AVO rides in my pocket, while the two knives which I have also carried over the last four yrs, the Umnumzaan and the large Sebenza, are languishing in the safe. WHY?
I think the major difference, to me, is a matter of physical blade and grip length. The AVO is just a bit shorter in both measurements, which makes it easier to manipulate "securely" and therefore more desirable for ME.
The grip-width of the AVO, the Large Sebenza and the Zaan are all within 0.005" in these three basic (and favorite) titanium slab-sided knives.
Below are several pics which show the AVO with a Large Sebenza (with lanyard)...
and one pic, below, of the AVO with my Umnumzaan...
The AVO, translates to me, as a "mid-sized Sebenza" that I have wanted for a long time." The small Sebbie grip is just too short for my hand, while the “large” Sebenza and the Zaan are larger than I would prefer.
The AVO...a bit shorter than either of the CRK's...seems to be a perfect fit for my hand-size. The cost of the AVO is on par with the CRK's, but I feel as though the quality exists among the three... in equal fashion.
So…YES…the AVO wins. I’m perfectly happy with its performance, its physical size and blade-width, and its appearance and comfortable carry size. Perfection personified.
Thanks for the comparison and review! The Avo sure is a fine looking knife. I hope we see CTS-B75p on some spyderco models soon, I'd love to try it out.
If you aren't on instagram it may be worth signing up just to see the pictures Brad (southardknives) posts showing his knife making processes. Good stuff!
Great review, thanks. I have the spyderco and have been very close for some time on pulling the trigger on the AVO. As strange as it sounds I'm now even more excited to get my hands on the Tolk.
Thanks, Sonny.
I have the Avo and the brown Spydie Southard.
The combination of Spyderco and Southard is hard to beat. The f&f on the Spydie is top-notch and I love that Sal & Co. are making some flippers. And, of course, it is half the price of the Avo.
Sadly, I don't care for the Spydie as much as I hoped and the main reason is the blade shape.
I wish it were more like the Avo. Or exactly like the Avo.
I don't get what that "hump" is supposed to add to the Spydie blade. And the thinner Avo just seems more useful for those of us not out on a camping trip.
I also look forward to the so-called Mini Southard on which Spyderco reportedly is working.
I also favor the Avo for its all-Ti scales -- I wish Spydie would do this with its Southard, Domino and Dice flippers.
Thank you folks for the nice comments. I am really enjoying this folder.
Flash900 had nice comments...per the following.
The Mini will be fun to try out and should be a big seller. Also, a thinner folder is much nice IMO, and all titanium scales is the magic formula that slims down a folder. Yes, I love the AVO. I like the black Southard very much, but all titanium would be a great improvement.
I've got one of these coming from a fellow BF member and I'm curious about disassembly. I've only carried sebenzas up till now and would like to know what I am to expect with bearings. Is it easy to do or not recommended?
Quick question for you.
I've heard that Brad's customs have some uber-smooth flipping action.
Is the action on the AVO significantly better than the Spyderco, or is there not much of a difference?
I have a TOLK on pre-order, and they are supposedly going out mid-Feb. I can't wait!!!
I just received my avo today and I'm impressed! I'm not much of a flipper guy but the flipper on this knife doesn't stick out to a long point like so many do. I mainly use Chris Reeve knives so the Ti frame and CTS-B75P (BG-42) really caught my attention. Blade dimensions are about the same as a large sebenza and the handle isn't much shorter but it fits the hand better than a sebenza does. Fit and finish are close to CRK standards although I would still hand it to CRK in that department. The blade shape is awesome! It seems to be somewhat of a cross between a drop point and what CRK calls an insingo. Looks to be a great slicer. The action is super smooth and fast. The detent is just right for a flipper action, strong but not impossible. Now just give me a couple weeks to carry and use it and really see what it's made of! 😊
Glock,
The action on my Avo is smoooth!
As to the Spyderco Southards, I now have three, two of which have been modded.
The action on two of the three Spydies is at least as good as that of Brad's Avo.
I think you will need another way to decide between the two instead of trying to figure out which is smoother!
Glock,
I'm still kind of new to this forum, so when you say "Modded", what exactly was done to the 2 Spyderco Southard's?
Was it some internal polishing or work you did, or did you send it out to someone to get it done? I've opened the knife up before when I died my scales black, so I'm familiar with what the spacers and bearing washer looks like.
Thanks for the feedback on the AVO, too!
I have one standard Spyderco Southard and two others that are modded to make them Minis -- with a 3-inch blade.
The pivots are unchanged.
I'll try for photos but I'm not so good at it.
I had a chance to handle a couple of AVOs about 8 months ago. When I was handling them all I could think about was how just handling them made them jump to the #1 spot on my list of useful, comfortable, and precision for the price knives I'd held. I'm a big fan of PSF27 so if I could grab one with that steel I'd probably not need another folder for quite a while. And I'm not even a big fan of bearing flippers, that one was an exception.
Oh OK. I thought you were talking about some internal mods that made the action smoother.
I have a few for the Spyderco Southard that I will have to try in the next week or so.
I would love to see pics of the Southard Mini's, and I'm sure I'm not the only one!
That sounds like me. I wasn't a huge fan of flippers to begin with but this one I just had to have! I had a flipper on bearings once and it had lots of blade play but this one is centered, no play at all, and extremely smooth. It's not too fast though either.
The BG-42/CTS-B75P type steels are high purity double melt VIM/VAR (vacuum induction melt/vacuum arc remelt) products. They are sophisticated steels, but since they are conventionally smelted, the Vanadium content is limited to around 2%. Powdered steels, on the other hand, can be loaded with up to 12.5% Vanadium (CPM-125V). I like high Vanadium steels because the Carbides of Vanadium Rockwell around 82HRC. This greatly increases wear resistance. When BG-42 came out, it was "better" than ATS-34/154CM (which had no Vanadium). CTS 204P has 65% more Carbon, 333% more Vanadium, and 140% more Chrome than CTS-B75P.
I have a Southard, but I wouldn't be inclined to buy an AVO unless they upgraded the steel. Nice looking knife though.
Excellent review!!! Thanks for that.
I am OK with the CTS-B75P/BG-42 as its easier for me to sharpen compared to CPM-121 REX or CPM S125V.
