A !VERY! detailed review of Huntsman knives
Moorik
Platinum Member
Well, gentlemen and gentlemen,
I come bearing a VERY detailed review of Huntsman Knife blades.
I mean, under a microscope—yes, literally.
There’s going to be a lot of text here and plenty of enthusiastic information that might help you understand just how well-crafted each model is. (I will literally show it under a microscope.)
There will be a lot of photos here, along with detailed notes on using the Fell Beast blade in real conditions. In a short time, I’ve probably put it through the equivalent of what 99% of people would never do with it over an entire lifetime.
I actually hit the maximum photo limit for a post — otherwise, there would have been even more.
The steel, or rather its quality, and the craftsmanship of the blade work are critically important—essentially, in my opinion, they account for 70% of any blade’s value.
I specifically conducted several tests like this with the Fell Beast, and later I’ll do a similar review with the Tyrant. These tests involved multiple sharpenings, followed by extremely tough use. The blade naturally dulls over time, I resharpen it, then subject it to very harsh tests for about a couple of weeks, and finally sharpen it a third time, just to solidify the results.
The test I’ll show, with the sharpening process, was extremely tough on the blade—probably a level of use that hardly anyone would put a blade through (I’m certain no one but me would).
So, here’s the deal:
For two weeks, I used it to chop large, dried boards made of hornbeam, oak, pine, ash, as well as firewood and pallets, where I encountered screws and nails. Here’s exactly how the blade, damaged by a screw, looks under a microscope—and, in my opinion, it looks pretty good.
The cutting edge of the blade only has dents, not chips, which is extremely good for Z-tuff steel that struck a screw.
The factory sharpening is very good, especially considering that the blade is large, which usually makes it harder to work with. The BTE (behind the edge) measurements along the entire length of the blade are well-executed and finished, and I didn’t notice any variation in angles or BTE values across the cutting edge, which is crucial for a machete-chopper like this, especially for a maniac like me who puts it through extreme use.
The difference in a couple of spots was around 1-1.5 degrees, which, honestly, is impressive for such a large blade.
I resharpened the blade to 24 DPS (24 degrees per side).
All of this is because I used the blade for tests it wasn’t designed for—heck, I was chopping unhardened steel bolts, striking aluminum, and more. I find it interesting to do this in a controlled context. Essentially, during tests at 21 DPS (21 degrees per side), which is the average factory sharpening angle, the blade was still cutting through screws and nails.
For myself, I sharpen it to 24 DPS. I always do my custom regrind on all knives at a slightly higher angle to subject the blade to insane stress, to understand its limits, and then reduce the angle later if needed.
The factory angle was between 21-22 degrees.
Here will be a photo of my custom regrind and how Z-Tuff steel looks under a microscope after using a 200/160 (roughly 80 grit) abrasive from the Poltava factory, with a copper-tin bond. This isn’t diamond—it’s Elbor, which is essentially the same but, in my opinion, slightly better.
The abrasive reveals the steel’s entire structure. Additionally, you can see the carbides and the grain structure. My microscope isn’t top-notch, and I’m just a forum nerd, so I’m showing what I can.
The steel, under the insane stresses I subjected the blade to for 7 days straight, chopping all kinds of wood indiscriminately—a TON of wood—remained sharp and could still cut paper.
Let me reiterate: I chopped a ton of firewood, took the blade into the forest, and cut down about five trees, each roughly 17-22 inches in circumference.
These were even tough, dry trees that made the blade feel like it was bouncing off them.
And after all that, the blade wasn’t cutting paper like a laser, of course, but it stayed sharp and handled things like bushes, small trees, and thickets with ease, even after one of the tests that lasted nine days.
Largely, good geometry is also about the fact that even when the blade dulls, it STILL gets the job done.
On a 150-grit stone, I started getting a solid burr, and I could see just how ductile and strong the steel is. Look at how large the burr is—it’s still holding onto the cutting edge.
It takes several passes to remove it.
I encountered this burr and was surprised; it even made me chuckle a bit. I named this burr "Zaedion." 😁
This isn’t paper or anything else—it’s definitely steel. A massive burr named Zaedion, sending you its regards.
Continuing with the same 150-grit stone, I noticed dents in the steel, still from the bolts I was chopping in my madness. Keep in mind this is at 250-300x magnification.
So, essentially, the steel shows no visible damage—at least the kind that can’t be fixed. Whatever damage was there can be manually resharpened, even by someone who isn’t the most experienced sharpener.
At 300 grit, with the cutting edge already formed, you can start to see the carbides and the structure, which is looking good. Additionally, at this stage with these stones, I can already feel pretty good feedback from the steel. The abrasives I use for sharpening are essentially a test for the steel through sharpening. Even good steel sometimes doesn’t provide good feedback or a satisfying feel for how it responds to sharpening. The formation of the burr, as you approach 250–300 grit, can vary, but here everything is EXCELLENT.The burr reflects a lot of light under the microscope, but keep in mind, this is at 300x magnification. In reality, it’s extremely, extremely small. At the same time, when switching sides during sharpening—that is, when flipping the blade—the burr moves to different sides with the help of the abrasive, which indicates that the steel is ductile.
At 800 grit, the burr is almost nonexistent, and I remove it completely. I go through these meticulous and complex steps to absolutely rule out any chance that I messed something up, ensuring my tests are essentially PERFECT. In fact, I don’t just do this once—I do it three times in a row! And by the third time, this result is exactly what I expect. Plus, I use oil with this abrasive, which prevents overheating and helps polish the edge better. (Don’t mind me, I’m just being a nerd about it.)
Essentially, at this point, you could stop, as the blade, with my custom 24-degree resharpening, is already shaving hair—not just cutting it, but splitting it in half.
But we’re interested in the steel’s structure and carbides, aren’t we? (Or is that just me?):rolleyes:
Here I moved on to the 14/10 abrasive, which is about 1000 grit, but in fact grit numbers are not a very accurate measure. The previous stone is supposedly 800 grit, BUT its particle size is 20/14 microns — that’s a huge difference in microns, while in grit it’s only about 200 units. (I’M BEING EVEN MORE PEDANTIC!)
Lots of carbides! And the steel is amazing, very beautiful steel! It’s a pity we lost the “Zaedion” burr:confused:
Here I reached 2000 grit, in microns this is 7/5, which already exposes the carbides even more, and polishes the edge, making it smooth, this is very useful for the blade to penetrate wood and other hard materials (f*ck I sharpen for 3-4 hours just to hit bolts?!?!)
That's the point gentlemen, if you look at previous microscopies, we see that a coarser abrasive and sharpening makes it so that we have a micro-micro saw on steel, even if it is visible when approaching 250-300-400, but it is in the micro structure (this is how sharpening works)
And I sharpen at very high values so that the blade is smooth and there is no micro saw!
I can praise the steel because when I sharpen at such values in microns, I do not get micro chipping in the steel, with a x350 microscope.
(95% of steel crumbles here)
Now comes the most interesting step, and I’ll explain it a bit more simply so as not to overload you with information and unnecessary words.
Here’s what I do: I go all the way up to an abrasive of 11,000 grit, or even 16,000, which corresponds to about 0.5 microns. I apply a high-concentration diamond paste onto a special abrasion-resistant strop tape, and then I perform stropping, polishing the surface.
But what’s the downside of this? The carbide structure itself gets polished as well — the carbides become smooth, along with the surface. This makes the edge feel somewhat “soapy,” meaning it loses cutting aggression.
So what do I do to prevent that? I polish at 16,000 grit, and then I go back to an abrasive of 3/2 microns (around 6000 grit) to expose the carbides. This way, I get a polished surface but with very, very AGGRESSIVE carbides sticking out. That’s why the cutting edge looks the way it does here. Overall, this kind of meticulous process shows what this steel is really capable of, and what it can endure in my tests.
On top of that, for heavy-duty work, such an edge actually becomes about TWICE as durable, since with a machete we chop and strike, rather than slice like with a regular knife.
So, what can I say about the Fell Beast in Z-Tuff steel?
It handled all the tests wonderfully. I re-sharpened it to my own liking, the way I prefer, BUT — the factory edge was extremely good. I used it for the first week without touching it, and it held up great.
As for the blade itself — the balance, the grind, and, most importantly for me, the steel. It’s excellent. The Fell Beast went through a lot: chopped down plenty of trees, I bent it, struck metal with it, and so on — and everything can still be resharpened by hand. On top of that, the steel is very easy to realign on a honing rod in the field. Z-Tuff is really great in that sense: you can touch up your blade even outdoors, and it will keep cutting.
As for the Fell Beast itself — even when the edge gets dull, it still cuts thanks to its geometry and excellent balance. As someone said on the forum, the blades Huntsman makes are “the 1% of the top 1%,” and you can literally see that even under a microscope.
P.S
I wrote part of this with the help of a translator, and the full text didn’t fit, so I had to shorten it a bit.
I hope the information I shared helps you understand just how awesome Huntsman’s work really is.
I did everything the same, and twice as much with Tyrant, as you saw from my posts sharpening at 0.25 microns :rolleyes:
I will definitely do a review under the microscope about Tyrant too
There's twice as much information 🫣
Absolutely awesome review! Thats a much better edge than I'll ever be able to get with belt sharpening.
Your feedback tracks well with my personal experience with Z TUFF
1. When it comes to chopping, the edge lasts a ridiculously long time. Between the hardness and toughness and that dash of vanadium, Z TUFF just really handles hardwoods well.
2. One of the few downsides of this material is that its very hard to strop. I think the Nickel content makes the steel "Sticky" for lack of a better term. Its funny but when I grind Z Tuff, it doesn't create dust like 3V does, it actually forms these long curly cues almost like when you carve wood and they aggregate into big tumbleweeds of steel dust. Haven't had that happen with any other steels.
I'm curious to hear your thoughts (any everyone's thoughts) on how Z Tuff compares to 3V in real world use.
Honestly, I've been incredibly happy with both. I have one personal user Tyrant Bowie in each steel and have tested the hell out of them both. For my big knives, I'll be sticking with Z Tuff because its much cheaper than 3V both to purchase and to mill and grind and I don't think any performance is lost in chopping and hard use applications.
The "factory" edge on your blades is 10/10.
Personally, I think the kind of sharpening I do isn’t really necessary in real-world conditions; it just really highlights the strengths of the steel in an interesting way. Both with your CPM3V and Z-Tuff, under a microscope and with such sharpening, everything looks perfect.
By the way, I wouldn’t even bother trying to make the knife sharper if I were you, because "too sharp" in many real-world use cases isn’t a good thing.
I sharpened my CPM3V Tyrant Bowie down to 0.25 microns, and you know, when it can slice a hair in half, it’s a bit scary to swing it around. So, for the first few hours 😁 , I use it more carefully because it’s just intimidating—that would be the case with any blade. You’ve found the perfect balance.
It’ll be interesting to compare the Tyrant CPM3V and Tyrant Z-Tuff in my tests.
You know, the Fell Beast surprised me because I had never used a machete before, but the Fell Beast completely changed my perspective on them.
Honestly, just intuitively, I think Z-Tuff, with your development and exploration of different variations, could be a game-changer. I haven’t seen anyone else use it in the context you’re working with.
That’s why Z-Tuff surprised me—because the Tyrant endured about twice as much abuse as the Fell Beast. With CPM3V, you kind of know what to expect, but the Fell Beast was my first machete and my first experience with Z-Tuff steel.
A really fascinating experience.
In this regard, you know, Z-Tuff feels like it has some unexplored side and room for experimentation, while CPM3V is used in so many places, and overall, what would you need to do to surprise people with that steel?
I’m confident that your blades made with Z-Tuff have an interesting future.
Awesome write up and review!
I hear you about the Tryant Bowie, I too took mine to .25 micron, and it pops hairs, which, with the weight of the knife is scary to even pull out of the sheath. Again, as you said, it's not necessary, and I sharpened mine at 18.8°, which I'm sure is not what was intended, but the factory edge was somewhere around 18.5° ish.
I'm looking forward to getting the Fell Beast in the next week or two, I've got some downed trees that are looking for some clean up.
Cheers!
That’s totally awesome!! Keep up the good work sharing your pics and progress!
I feel honored having the toughest, stiffest z-tuff burr named after me! 🤣
Moorik Moorik GreX GreX what kind of sharpening set up do you use to get these kind of results? 🤯👏
I use the TSPROF K03; they seem to ship worldwide, and the price is around $900. It’s not cheap, but it allows for great results when it comes to fixed-angle sharpening. To be fair, though, I spent about a year sharpening by hand before this, so I still have some manual skills that help me use the grinder. Back in the day, I looked like a samurai sharpening a blade on a whetstone, but honestly, that’s not very efficient and limits maximizing results.
Any fixed-angle sharpening system is good in this regard, but in reality, the machine is only about 30% of the work. Around 70% depends on skill, choosing the right abrasives, using a microscope, and so on. I do this as a hobby that also makes me a bit of money. I got into it because my main job involves sitting at a computer—I trade stocks/crypto and work in that field. So, this kind of hands-on work is really cool and beneficial. Plus, I’ve started going out into nature more often and generally breaking away from the routine.
The toughest burr just *had* to be named after you! It’s great to be part of a community like this, guys. It’s awesome that we’re all here because of the blades Huntsman makes.
!Nerdy info alert!
I sharpen with a variety of abrasives—I have a collection of a few hundred different ones. Through personal experimentation, trial, and error, I’ve figured out how to sharpen the cutting edges of various steels and knives more effectively. It’s honestly surprising how much MORE you can get out of steel with a PERFECT sharpening job, which can only be achieved through long, meticulous sharpening and careful burr minimization.
For sharpening Z-Tuff and CPM3V from Huntsman, I usually use CBN (basically a diamond abrasive, but better in some contexts, producing a more durable edge) or a cast iron lap with high-concentration diamond paste applied, along with oil to aid in polishing. The result is roughly that the cutting edge lasts 2-2.5 times longer, especially in heavy-duty tasks.
video of sharpness at 22 DPS
I'm also using the KO3 with either diamond or CBN stones - I too started with some cheap bench stones, then progressed to proper bench stones, and a couple diamond plates, but the fixed angle is the main use these days, makes it easier, repeatable, and consistent. I'm still a bit of a noob, only been at it for about a year and a half, but for sure the best results I've ever seen from a knife.
After very long tests and sharpenings,and resharpenings, I decided to do a review on the Tyrant Bowie CPM3V, as promised.
The blade has been through A LOT, no, I mean REALLY REALLY A LOT—cycles of my strikes on wood, stones, metal, and chopping a screw, which, to be honest, I didn’t intend to cut (it just happened to be in the wood by chance).
The amount of work involving strikes on wood, cutting through bones, hitting horn, and other tough tests for the blade—then I checked the sharpness, and it was still there, the blade still cut paper.
What’s extremely important, beyond the steel, is that it’s incredibly comfortable to work with. Thanks to the geometry, balance, and other factors, the blade is literally a tank that can punch through ANYTHING.
I’m deliberately explaining this as a simple fact: my Tyrant even looks like it’s showcasing the sheer amount of tough, and perhaps even undesirable, work it has endured. This speaks volumes about the quality of the product, the steel, the excellent geometry, and the overall craftsmanship of the blade.
And as is tradition, after the enormous amount of work done by the Tyrant, here’s a microscopy photo showing the most severe damage.
I called it the GreX great dent (in context of 450X microscope)
This dent came about because I chopped through a screw on a whim, which was accidentally embedded in the wood. It’s the most damaged part. By the way, even after all this, the blade could still cut paper, meaning it remained functional. Honestly, at first, I didn’t fully understand how it was possible that the steel could take such abuse and still hold up so well.
After subsequent sharpening and microscopy, I finally figured out what was going on. And you know, Hunter, despite presenting his blades very modestly—seriously, he does it with no extra pomp or hype—I think he’s got some kind of secret when it comes to CPM3V steel and Z-Tuff as well. He knows something, I’m sure of it.
You know, a few things have changed in my process. I’ve started doing it with greater abrasive hygiene, using a slightly different combination of abrasives. On top of that, since I’ve sharpened the Tyrant 10 times already, I know literally every nuance of its geometry transitions, so I was able to maximize the results.
Also, I upgraded my microscope and changed the lighting, so you’ll be able to see everything more clearly and in greater detail. When you sharpen a blade for the 11th time, you get a different result—WAY COOLER than the first few times.
A special thanks to CNC and the work on the blade, because honestly, it’s a real pleasure to work with this geometry, and the sharpening can be maximized thanks to the smooth and even transitions on the blade.
Here we have the classic 150 grit at a high micron value, and here it’s 100/80. (This means that with lower grit, I get a good abrasive structure, which allows me to achieve better results when polishing the blade on soft stones.)
Here’s my classic 50/40 bar with a 280 grit rating. I’ve started combining Diamond and CBN with different bonds to examine the carbides and steel structure—it’s fun, interesting, and tells us a lot! Just take a look at the steel structure we see after using this bar.
You can see how aggressive the steel is, even though it’s supposedly just CPM3V.
(It’s aggressive, yeah, and I know how to assess the toughness and strength of steel literally through microscopy.)
Here’s 700 grit on a 20/14 micron stone, which is softer because I switched from a diamond abrasive component to CBN. It’s gentler and works well with this steel.
By the way, this particular stone often doesn’t grip the steel as well if the steel isn’t aggressive, rigid, or strong enough. Here, I literally feel the impact of how the abrasive and the steel interact—they practically grab onto each other, like they’re magnetized.
At 1500 grit, which is 14/10 microns, we start to see the carbides, the steel structure, and we can’t help but smile, get excited, and take pleasure in the stunning view through the microscope.
(I definitely have a talent for writing—maybe it’s time to start doing reviews in the style of detective stories.)
2500 grit, at 7/5 microns, is a pretty important stage where you need to neither underwork nor overwork the blade, so the next abrasive can do its job properly. Essentially, this is a filler stage—it’s there to set up the magic I’ll pull off in the next step. I promise, you’ll be amazed.
(The carbides are stunningly visible—I’d even say it’s a Zaedion's meadow of carbides.)
Here we’re at, roughly speaking, 3000 grit, but the micron value is more important—5/3 microns. Just look at how high-quality and impressive the steel looks. And HERE, I can be confident that the work done on this steel, and the way it’s crafted overall, doesn’t feel like just some “standard/ordinary protocol.” I can say with high certainty that some serious work was put in here, and Hunter knows something—I’m sure of it.
He talks about his steel very modestly, but you can see the uniformity and quality. This is REALLY good, which is exactly why a random strike on a screw only caused a TINY dent. And the blade withstands SO MANY strikes while still cutting paper afterward. The steel literally rewards me for the amount of work I put in to expose the carbides, polish them, and then reveal them again! It all makes sense because the steel is perfect.
Here’s 4000 grit, 3/2 microns.
Now just look at how it appears polished and how uniform it is.
Also, this is an intermediate stage for the final result.
Here it is, the final result I achieve in the ideal scenario: the steel and blade shine brilliantly. I raise the angle by 0.05 degrees to definitively remove the burr with a light motion. At this point, I make the blade sharper than your razor—I could literally shave with the Tyrant, but it seems a bit too big for a razor.
I haven’t yet achieved such a clean cutting edge, and nothing at 22 degrees per side has ever cut like this. Here’s the usual video.
Do you know why I’m doing this?
Because, to be honest, the community of people on this forum is literally the best one I’ve ever come across.
I’ve never received so much interest and support for the craft I practice.
I’m genuinely excited to do this, to share my experience, and to help you take a look at the Tyrant now under x450 magnification, examine the steel, appreciate its qualities, and understand the limits a blade is capable of.
And it’s capable of quite a lot.
Thank you guys for appreciating my small effort.
P.S
I'm new to the forum, and new to sharpening in general — I’ve poured a lot of time (and money, haha,but i love this) into this hobby.
I always check under the microscope to see the effects of heavy use on a blade. Man, guys — I’ve hit it against horn, bones, a screw, and hard wood; I’ve planed and cut with it — and the steel is extremely good. It’s awesome to be one of the first to evaluate and sharpen it and then inspect it under the microscope.
Thanks to Hunter for being the first to appreciate this small piece of work and leave feedback. And thanks to everyone who sees this post — so many people have supported my sharpening reviews and results here on the forum. I’ll keep sharing interesting stuff, improving my microscopy and sharpening quality, and pushing things to the MAX to see what Huntsman blades are really capable of.
I’ve never used anything this hard before — at times I thought I’d break them, but they basically only suffered scratches or small chips on the cutting edge.
Awesome review! I love how you can see the steel clean up with each grit progression under the microscope. Thanks so much for sharing your findings with us!
I do lots of testing myself, but I don't always believe the validity of it until someone else replicates it. Its great to see someone putting their blade through the gauntlet!
Hunter is gonna have to hire you for testing and marketing ;) Good stuff indeed - out of curiousity, what microscope are you using? I use a jewelers loupe, but that seems to be a pain in the but most of the time.
You know, I use the Carson x250 and Carson x500.
I took them apart and modified them, which cost me a mere $200 in total.
But here’s the thing: if you’re not planning to take photos and post them like I do, just go with the classic Carson x250 and don’t bother with customizing it.
I basically modded mine to better see carbides, get light on the spot I’m looking at, and share photos.
It’s actually much simpler than it seems. Once you start using a microscope like that, your perspective on sharpening that “turns out great” completely flips. You find a TON of flaws and things to fix.
And when you get to the point of sharpening under a microscope and start noticing how different abrasives work on different steels, you’re amazed at how much you can get out of good steel, like on the Tyrant and Fell Beast 😎.
If you, or anyone reading these messages, are interested in the details or specifics of the sharpening steps, feel free to write to me, and I’ll gladly explain everything!
Before this, I also used a jeweler’s loupe, but it’s a pain 😂
Honestly, I did an experiment: even without a microscope, you can sharpen pretty well, but here’s the interesting part 😅
You need to look through a microscope, understand certain things, and compare how it looks with and without it. Then, essentially, you can already get a good result, though it won’t compare to when I inspect the ENTIRE length of the blade to maximize it.
But sometimes I’d challenge myself to sharpen a blade in, like, 20 minutes, and it turns out decent. However, to get there, you need to understand the context of how things look under a microscope and without one.
Trust me, just getting a good lamp and a white LED flashlight will do more good than a jeweler’s loupe (I used one myself for half a year).
Amazing! Thank you so much for taking us on the magical journey to the meadows where carbides shimmer!
Kinda wishing that you have a youtube channel where you take us through the ins and outs of pushing sharpening to its absolute peak!
You know, to my surprise, each of the videos got 100 views. It’s not a huge number, but it’s cool to see that people are actually watching. And these are even random viewers on YouTube. (But initially, it was you and the people from Bladeforums.)
But I also realize that if I’m going to make something like a video where I explain this, I want to do it with decent quality and make it informative—basically, share something I haven’t seen on YouTube before.
If Hunter doesn’t mind me using this forum thread as a platform to post such a video with educational content, I’d be thrilled.
I totally get that in this context, with such in-depth information, it’s interesting to a small group of people, and as it turns out, to you guys too!
Honestly, Hunter initially motivated me to do this just by showing interest and support for what I was sharing with him.
And now you guys too—honestly, I didn’t expect it to be *this* interesting to you.
I’ll definitely figure out how to make a video about this, probably in a few parts.
Thanks, dudes!
P.S.
I have something like an idea—to show how it all works not just on paper or whatever, but also on wood, with strikes, planing, and so on, to demonstrate how useful it is in real-world applications.
I’ll definitely think it through.
Well, you guys asked for a sharpening video guide filmed on an iPhone. For me, I see it as a chance to improve my spoken English and solidify and structure my sharpening skills.
For some reason, it was the Huntsman knives, and Hunter in general, that sparked this in me. Honestly, I’m not even exaggerating—I’ve sharpened over 1,000 different knives before, and I never had this urge to show it to anyone or dive so deeply into examining the steel under a microscope, comparing it, and so on.
Z-Tuff, which Hunter makes, is currently an intriguing mystery to me, even more so than 3V.
I keep trying to figure it out and understand how to maximize its cutting edge.
Even though I’ve worked in the context of sharpening with steels like Rex-121, Maxamet, CPM15V, ZDP-189, S90V, S110V, S390,Tungsten Carbide,S125V,Rex45,PM60,S60V,S90V and all sorts of rare steel variations whose names wouldn’t mean much, for some reason, steels made purely for cutting don’t captivate me as much as those designed for heavy-duty work.
iPhone video and your English is just fine! Don't need to over-complicate things when you can provide immediate value! 👍
Speaking of uniqueness for your channel, besides taking us through your processes and nuances of sharpening knives, you could also talk about trading tips (with a BIG disclaimer that this is not a financial advice, you're responsible for your own investments... yada yada yada). That way we all could possibly afford more Huntsman knives while making them as sharp as can be! 🤣
Well, I like the vibe in the community 😁
Looking back, I don’t even understand how we got to all this.
A huge plus is that it’s not about toasters, and our lives have gotten better 😎
!!!ALARM!!! CRINGE ALERT!!!
Strike while the iron is hot...!
So, I spent about a couple of hours filming a video, making a stand out of napkins, a couple of weightlifting plates, and my phone as the camera.
I wanted to make a longer video with sharpening using all the stones and a finish, but it seems to me that it would be more consistent to just show what you can achieve even with a 150-grit, hard stone, and do the finishing strokes with it.
Alright, guys, I'm waiting for my 8 million dollars for the video, as we agreed.
Then I can spend 500 dollars on a camera, and the remaining 7,999,500 dollars I’ll spend on Coca-Cola.
Oh God, what have you gotten me into...!
