Now I'm really confusedbig no-no, I had the same issue when deciding. I do have knives in both A2 and O1, but nothing smaller and thinner than larger blades. Here is what Rod emailed me when I asked:
"A2 is about 10-20% tougher than O1 and will hold an edge a little longer. O1 will be slightly easier to sharpen and also will allow the user to strike a spark off the spine using the flint and steel method of fire lighting (A2 has a little too much alloy to get a good spark). Since A2 has a higher chromium content it will be a little more stain resistant than O1, however both will rust if not wiped down after use or abused. Both are excellent knife steels and will give you good service." ---Rod Garcia
I'm not sure if he does his own in-house heat treatment, but I decided to go with O1, just because I want to try out that in a thinner blade for camping.
ROCK6
Now I'm really confusedHow many people are stiking good sparks with the Bark River Northstar, a bush knife practically designed with this in mind, made with A2. Any A2 users out there know if this steel is useless with a ferro rod?
