- Sep 16, 2015
Can't find replacement vise jaws, so I am going to make some new ones with the closest spec I could find to my originals. By specs I mean physical size. The cheapest precision ground steel that I found I could use for this was annealed A2 precision ground at McMaster.
I would like to make them a bit harder, but I dont want to commit to them going in the kiln to fully air harden and then temper like a blade. It is arriving at a Rockwell of B90, so I plan to machine the holes (slots, since I would like to be able to adjust the height slightly) while its currently annealed and then harden it up a bit.
Would you either toaster oven it to a specific temp for specific time, or propane torch to a specific color? That is kind of where I am at with it. I dont want to introduce scale, as I need the main surfaces of the chunks to be precision ground and parallel. I do have an evenheat kiln, but I dont want to use it. Wonder if anyone has done anything similar.
