So I am using a paragon KM14d. My process was preheat to 1100 put blank in, hold at 1100 5 minutes giving me time to get the blank in and for it to begin heating ect. Ramped full to 1775 and held 35 minutes. Blank was in a stainless pouch. I pulled the pouch out and hung it. I could somewhat see the outline of the blade in the pouch from it being orange. I let it hang in the pouch until I could handle it then removed the blank. Initially I filed off a very thin coating of Im assuming scale which was extremely soft. At first I thought the blade had not hardened at all but soon realized I was just digging out this material. After grinding the belt to 65x Norton and file testing I could tell it was hardened. The issue is it doesn't seem anywhere near as hard as my 1084 blades which are post temper. Any ideas on things I could try or change? My next plan was to preheat to 1400F and hold for 10 minutes. I got this process from an experienced and successful knife maker and I trust his results however it doesn't seem to be the same to me. Could this steel really be that much different that 1084 as far as maybe its tougher but not as wear resistant or something and that's what I'm seeing? My file is almost incapable of effecting my 1084's with the A2 if I push I can get scratches and get the "hung up on something" feeling as the file sweeps across the blade.
Also, any ideas on the average time it takes a kiln such as the km14d to evenly soak a blade to temp, meaning, If I stick a room temp blade in a 1100 degree oven, how long would it take to get to 1100 degrees? Further if its in an oven ramping to 1775 how long would it take to bring the blade temp up as the kiln temp increased to 1775? If I was a soak for 35 minutes at 1775, should I add a certain amount of time to the actual program at 1775 in order to account for the time it takes for the blade to actually REACH 1775.
I've read that an experiment was conducted on tool steel and that OVER soaking(in time not temp.) it had no negatives, merely diminished returns as to make it not worth it, while under soaking is when you run into issues so I don't want to be on that side however I'm also looking for the most economical way of treating blades.
For the record I am already planning on recording my programs and testing numerous blades to get what I want, just was hoping for someone to help me out with your experiences. Thank You in advance
