Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Ok coolBrian Bazeal makes anvils like Sam's out of mild steel. The most imortand thing is to fasten it securely to the stand, and fasten the stand to the earth! The nice thing about an anvil like that is the dings can be ground out.
No need to harden it.
Cheap anvils aren't cast iron ...they are cast steel .....big difference.
Some of the older anvils are wrought iron with a hardened steel top plate.
A block anvil will work if it has enough mass, and the face is smooth. It is better if hardened, but that takes equipment and procedures beyond the scale of most makers. If you find something big enough, it can work. A solid stand is important.
I regularly see small anvils for sale around Norfolk. Check the trading Post and Craig's List. Put a "Wanted to Buy - Anvil" add in both. Other finds can be had at the local scrap yards.
At Daniel Boone's Pasture Party each spring, there are dozens of anvils for sale in the tailgaiting area.
http://www.bladeforums.com/forums/showthread.php/825297-Pasture-Party-Pics
Give me a call or email if you want, I can loan you an anvil until you get one that works for you.
We never did get together and let me see your shop.
Well i was reading some where that a36 is miles better to use then cast iron, and there are cast iron anvils out there.
And i would be using a paragon kiln and do a long soak time. I guess my question is can you get a little more hardness from a36 with a heat treat
