Since torx driver edges are kind-of sharp, you could try taking the next size up torx and jamming it in the stripped screw. This will ruin the screw even more and you definitely won't be able to use it again, but at least you might be able to get it out.
I'll try.
Seriosuly, why can't Spyderco just use a phillips instead of the easily stripped torx?
Torx screws are very hard to strip if you are using the correct driver.
Try superglue on a cheap torx driver head. Let it set up, then try to back the screw out
I'll try.
torx are quite hard to strip w/ correct size bit.
problem is that torx heads will happily accept a half-size smaller bit and then SEEM to engage![]()
I've already given up and am currently rewarding my failure with a beer. I think I may just take the easy way out and send it to Spyderco.
Thanks for the help guys![]()
