- Jun 21, 1999
This is getting frustrating. I've been quenching steel for 6 years now and forging for two. My feeling about this is that I should be getting better, NOT WORSE!!!
OK heres what I am doing. See if you can shoot some holes in my process. I pre heat the forge. I turn it off and stick the steel in to warm it up gradually. I then forge to shape. Next I heat to critical and let cool to handling temp in still air three times.
I grind to shape going from 36 to 60 to 120 leaving at least a dime to a nickle's thickness at the edge. I then normalize again three times. Then I heat my oil (olive oil) in a 12" diameter 6" deep dutch oven to 145 and bring my blade up to non magnetic, let it soak for about 10-15 seconds then pull it out and quench immediately (maybe 1-2 seconds later).
I've also had some steel just crack as I was forging it last winter...same batch. It was a nice orange color, not black. It cracked at the end I was forging, and also at the cold end in my hand. I got rid of that bar.......
Whaddya think? Am I doing something dreadfully wrong? Or should I just throw whats left in the lake and get my steel from somebody else?
Unhappy Cat
Unhappy Cat
