not2sharp
Platinum Member
- Jun 29, 1999
The now discontinued Buck Buckmaster (Model 184) had a very enigmatic feature; two round pins (anchors) which were threaded to attach to the guard. The assembly had a design strength of 600 lbs, and was designed to work in conjunction with a heavy rotating lanyard ring mounted near the pommel.
I don't know how many times I have heard this feature described as a grapple. But, I am certain that that is not what it is. You were not supposed to throw the knife over a castle wall to scale it. Such a move would have been darn dangerous to one's health; not to mention, it voided the warranty.
When in doubt it always pays to look at the obvious. The reason these pins were called anchors is because that was precisely how they were intended to be used. We should recall that the knife was originally designed for the US Navy Seals and intended as a diving knife. If you are planning on going in with scuba equipment, and have any hope of carrying out a precision attack, you will have to stage the attack before it commences. You may need to hold in place off some beach head while waiting for the rest of your team to get into their positions. It is hard to just float in the ocean, and swimming against a current is exhausting at best. But, if you can jam the pins on your buckmaster under a rock, you could simply tie into the lanyard and just float around and relax.
That is probably how this feature of the knife was intended to be used. So, if you have one these, don't throw it. Instead, you should just place it in position and float away.
n2s
n2s
n2s
n2s
