Absolute Proof (Sebenza Fit and Finish)
people know that CRK knives are known for their exceptional fit and finish. but hearing numbers that quantify said F&F may be a bit confusing (not many of us can relate .0005" to something we know) i promised a friend of mine i would measure the thickness of the washers on my sebenza the next time i took it apart, i figured since i had my camera and calipers out i might as well take a few more pictures.
hopefully these pictures help understand the F&F on CRK knives.
note the fit between both the bushing/blade and bushing/female side of the pivot screw is five thousandths of an inch. :eek:
sebenza washer thickness
diameter of hole drilled in the blade where the pivot pin/bushing reside
exterior diameter of bushing
interior diameter of bushing
diameter of female pivot screw
FYI- Calipers are not an accurate measuring tool...You would do well to measure anything close to ±.001 repeatably with "very nears"
But I can tell you the tolerances are very tight..Have made a few parts for sebbies many years ago. :)
I have no idea what in the world I am looking at.
the dimensions of the various parts that comprise a sebenza. for example the hole in the sebenza blade to accommodate the pivot screw and bushing is .2575" the total diameter of the bushing is .2570" thus there is a 5 thousandths of an inch of space between the bushing and blade. in other words excellent fit and finish
maybe, but they accurately measured bullets when i was reloading (to the thousandth)
the title was my attempt at humor, like i said in the first post people know that CRK's have tight tolerances. these pics were meant to illustrate that tolerance.
According to the calipers, that's a 5 ten-thousandths-of-an-inch difference (not 5 thousandths) between parts. But like bhyde mentioned, I would not consider those calipers capable of measuring ten-thousandths.
I meant no disrespect at all, if I came off like that, I sincerely apologize!!
BTW- I have that exact pair of calipers at work- well, 3 pairs, 6,8 and 12inch. Glad to see someone else using the same quality tools :)
Yeah baby - thats what I'm talking about.
I'm an engineer - so I'm all about someone actually posting with real info.
That's why I own a few CRK knives.
If you've ever had to build anything you will appreciate these tolerances.
Thanks for making the effort Gundude73!!
The tolerance is very impressive. I met a Marketing rep with Strider a few weeks ago when I was in California and he was even stating how impressively tight the tolerances where on the Chris Reeve knives.
There is a reason its the standard by which all others are judged. Even more impressive is that its a production knife not really a full blown custom. To consistently pull this kind of tolerance off as Chris does is a minor miracle in its own right. I've always applauded his efforts! :thumbup:
STR
Nice idea, thanks for posting. And yes, I agree-the tolerances are very impressive.
STR
I may be mistaken (please feel free to correct me if so :D ) but I would expect that hitting those tolerances on a semi-production basis is probably harder than on a one-off custom basis?
What should be more impressive if others with calipers take similar readings...too bad mines out of batteries =*(
