Absolute Rookie reports in - no pic's :)
I just started this hobby and here’s what I’ve learned so far.
The 4x6 metal bandsaw from Harbor Freight, Delta, Jet and one or two others are the same machine. Find the best price including shipping and get that one. Take off the blade that comes with it and get a Lenox bimetal 18 tpi. It cuts like a hot knife through butter compared to the factory blade. You can spend lot’s more for a band saw, but you don’t need to.
The Grizzly knife belt grinder does well enough for a beginner as I’ve found you can waste just as much money on badly ground blades on that as a $1,000 Bader. I can see the need, eventually, for a variable grinder speed grinder once I figure out what I’m doing and with lots of practice. I have the optional 10” wheel and the factory 8”wheel for the Grizzly. I prefer the 10” wheel. Even with just 1hp, you can’t stop the belt.
The sanding belt shoe on the Grizzly has a canvas, graphite coated ‘pad’ for a belt backing. This wears out in almost no time and becomes wavy making a decent flat grind here almost impossible. Reading from the forums here, I have epoxied a 2x9x1/4” piece of plate glass to replace the canvas pad. I’ll let you know how well it works. Several others here swear by it. Check the archives.
If at all possible, drill all the holes for pins, bolsters, weight reduction, etc before you profile the blade edge. Eventually, a blade is going to get ‘grabbed’ by a bit in your drill press and start swinging. It will take a few days off your life when that happens. A dull piece of steel will still hurt, but probably a lot less than a semi sharp blade will. When you do profile the blade edge, leave a 1/16th on the edge for the very final sharpening.
Don’t underestimate super glue. A dab on a bolster or scale to the tang will hold just enough to help when you drill a pin hole. When you are done drilling, just knock it off. I can’t recall where I picked this up, but it is one of my favorite tips.
Blue painters tape (looks like masking tape) peels off easy when covering a sharp blade and leaves no gummy residue like duct tape or masking tape.
The Norton Norzon Plus 60 grit belt is unbelievable. It cuts metal and lasts longer than any of the others I’ve tried. Worth the money. Industrial Abrasives has belts that work out to $2 apiece when you buy 12, get 12 free for $48 bucks. They are not great but at 2 bucks apiece, they work good 'nuf.
A dremmel will flat mess up a blade. It’s just too hard to control evenly. I have three dremmels and use them often for this and that. I cuss them every time I use the damn things.
Bigger isn’t always better. (I know, I know.) I thought bigger hand files would be better ie 12”, 14”, 10”. I tend to use the smaller ones more since I find them easier to control. Maybe with more experience, bigger will be better. The cheaper the files, the quicker they dull. Nicholson brand seems to work well. There is bastard cut, second cut and smooth cut. The bastard cut leaves deep scratches that are tough to clean up. I use the second and smooth cuts more often. Grind the teeth off one of the edges on flat files for tight inside edge clean up. Clean the file often, it helps.
You can’t have too much micarta. It makes great blade templates, sanding blocks/sticks and push sticks.
Scientific graph paper is the easiest I’ve found for blade drawings and layouts. I draw a blade, cut it out the paper template, transfer it to the metal, once the blade is profiled on the grinder, I trace it back to the graph paper for a reference copy. It’s all a bit anal, but it works for me.
If I ever manage a sharp grind line or decent plunge cut, I’ll let you know.
Sounds like you have a great grasp of the fundamentals. Now go out and grind so we can see your work
R.W.Clark
That's one helluva great early post and some great "news from the front".
