Here is a post I found that explains it some:
#25
mrpinkbullets
mrpinkbullets
121Dec 3, 2009
Flicking your knife WILL NOT void your warranty. There are, of course, some qualifications:
- Thumb flicking is PERMITTED in almost every case. Of course, it is preferable for you to flick gently, but even harder thumb flicking is unlikely to cause significant or even noticeably increased wear on the blade tang or stop pin bushing. Then again, many people find it difficult or impossible to thumb flick their Seb because of its tight action, so this is often a moot point. If you can flick yours, then go ahead.
- A gentle wrist flick is RECOMMENDED after every cleaning, oiling, or other disassembly. Chris himself suggests it, to "bump" all the parts into their proper place after the knife has been reassembled, and to ensure a good lockup.
- Frequent wrist flicking is NOT RECOMMENDED, as the Sebenza is a very carefully constructed and finely fitted knife that depends on its precision and close tolerances to deliver reliability and smoothness. Hard wrist flicking WILL eventually cause significant wear to the tang and stop pin, and it WILL be detectable by CRK if the knife is submitted for warranty service. It's not likely that your lock will fail in any dangerous way, but you will lose the smoothness and precise fit that I'm sure you've come to know and love.
Most of the information here comes firsthand from Heather at CRK, so you may feel free to treat it as gospel. I thumb-flick my Small 21 as a matter of course, and I have yet to see any negative effects on the knife as a result. In an emergency situation, if I am wearing gloves, if my life is in danger- whatever- of course I will not hesitate to slam the blade out with an aggressive wrist-flick if necessary. In that situation, the warranty service on my Seb will naturally be the last thing on my mind. In every other situation, though, it is NOT advisable to wrist-flick as a habit
