afishhunter
Basic Member
- Oct 21, 2014
A vid on You Tube by Filex Immler says yiu can acid etch stainless steel using the liquid or powered acid used to clean coffeemakers (among other things) using a 30% strength solution, without taking your VIC SAV apart. The acid does nor affect the aluminum or brass parts, like the acids that require taking the knife apart.
He showed a SAK (not sure which model) he had acid etched. However, I am not sure if the now matte black scales are original or aftermarket.
I loathe "mirror polished" fingerprint and smudge magnet blades. Also, I have a metal signalling mirror in my kit, so I do not need my knife's blades to double for that use.
My question:
How does that acid react with unsealed/stabilized wood covers.
(I am going to guess since bone and coffeemaker slag are both calcium, it will damage unsealed/stabilized bone and stag/horn/antler/tusk covers. I think all abalone, pearl, and other shell covers are thin sheats sealed in a clear acrylic. If not, then the acid would destroy them as well, sice they are calcium, as well.)
Would that acid affect Micarta, G-10, and pre-2004 Delrin/Staglon?
Will it dissolve Cellidor, or just give it a matte finish?
Will it give shiny acrylics like Case, (among others) uses on some knives, a matte finish?
Thanks for your input and wisdom in advance.
My question:
