- May 26, 1999
I recently etched a design onto a knife blade. I used the process described on Chiro75's web site, which is probably the most basic method. It just involves coating the blade with wax and carving a design into it. I used the PCB etchant from Radio Shack which consists of ferric chloride.
It turned out pretty well. You can certainly tell it was done by an amateur, but I'm pleased with the results. I think I could use a stronger acid though. I started off with a diluted mixture and eventually ended up using the ferric chloride at full strength. However, the etch is still very shallow.
So, my question is: What other acids could I use and how could I obtain them? In a past post, I remember reading about aqua regia. Has anyone used this and how do you make or where can you buy this? Are there any other acids I should look at? Thanks in advance for any help.
