I've been reading up on the various uses acid has in the knifemaking world. I picked up some ferric chloride and sulfuric acid a month ago in anticipation of needing them some day. The more I read about them the more concerned I get about safety (no experience with either). As with most things there are little 'gotchas' and one in regards to acid I read was do not pour water into acid, pour acid into water. What are some other concerns the average Joe wouldn't know about like that? I have a couple of questions to start it off:
How bad are the fumes? Is indoors ok and should I wear a respirator? If so what type of cartridge is required?
How do you guys store it? I've seen folks use it and it would appear they are storing it in a PVC pipe mounted to their bench. Seems dangerous and that it may leak fumes if not properly sealed. Concerns with this?
When neutralizing acid I've heard water, baking soda, trisodium phosphate, etc. Do these work for all acids or do they each work for specific acids? In the case of ferric chloride and sulfuric acid what neutralizes those?
Thanks in Advance!
Thanks in Advance!
