- Apr 6, 2013
I have a AG Russell Acies. I've noticed that i cant bring it back to factory sharpness using the lansky system. anyone have any tips for this steel?
" The sharp maker will work a bit slower than something like DMT diamond stones but it will work.
Keep the angle perfect, use light pressure with the finer grits, strop it and view the edge under magnification. YOU WILL GET IT... unless you give up.
I recommend try it on a Japanese water stone. Well a good water stone will do.
It could be that you aren't hitting the actual edge. Sharpie up the entire edge and sharpen on the 30 degree angle; see where the sharpie gets worn away. The actual edge is likely in between 30 and 40 degrees.
