AD20.5 pocket clip screw size?
I replaced the Grivory scales on one of my D2 AD20.5 knives and need pocket clip screws about 1mm longer. When I measure the original screws, they seem to be M3. x 5mm long (with T6 button head). Is that the correct measurement?
Thanks for any help,
Bob
Edit to add: M3 screws are too large in diameter. I have some M2.5 on the way.
Excluding the pivot, there should be (6) T6 screws. The (2) that hold the stock pocket clip are slightly longer than the rest. Did you accidentally install those in the scales, leaving only the shorter screws remaining?
The two longer screws are indeed in the pocket clip and are too short with the thicker aluminum scales in place. I have a pair of M2.5 x 6mm screws en route. (the M3 screws I had in the shop were too large in diameter.)
