Adam Gray (AA Forge) Scandi Bushcrafter review
Adam Gray has been on this forum for a while and even has his own subforum, but remains a bit obscure. I'll do my part to help spread the word about his stuff by reviewing the one AA Forge knife I own - the Scandi Bushcrafter.
The design is extremely simple and efficient... no guard, choil, jimping, or lanyard tube. It is built from 1/8" thick O1 steel with forge-finished blade flats, 8 1/2" long overall with a 4" flat scandi ground edge. The blade flares slightly out from the handle and is exactly 1" wide at the base. The spine has a gradual and continuous curve from the handle to the tip, and the cutting edge runs straight for about two inches before curving upward to the tip. The tip is positioned about 3/16" higher than the centerline, making the blade somewhat of a hybrid betwen a spearpoint and drop point configuration.
The handle features a full exposed tang with black linen micarta scales and brass pins. The handles are nicely rounded, which is an excellent feature on an exposed-tang knife. This design combines the comfort of the oval-shaped handles on stick-tang knives with the strength of full tang construction. The handles have very slight contouring and flats ground in at the top for side-grip positions. It is smooth and amazingly comfortable.
Adam supplied a kydex sheath by Gray Wolf Knives (Aaron Gray), who is perhaps related to Adam (just a guess). This sheath fits the knife like a glove - the blade locks in tight and draws smoothly with little noise and friction. This knife has been in and out of its sheath more times than I can remember by now, and I can see only one area where the kydex has left some small marks.
An addition to the sheath is an open-construction belt loop with a slight barb on the inside. The sheath can quickly be snapped onto my belt and no-so quickly removed as the barb snags the bottom of my belt quite nicely. Getting it off is actually a bit of a chore, which is of course the whole point. It reminds me a bit of Bud Nealy's MCSII barbed metal clip, and is an excellent design that was perfectly executed.
Right out of the box I noticed that this was possibly the sharpest knife I've ever purchased. Upon closer inspection I realized that the grinds were absolutely perfect. The blade bevels and scales are almost mirror images of each other. Having bought many custom knives, I'm pretty much used to uneven grinds and have gotten to the point where they have to be atrocious before I even bother complaining about them. I suppose even grinds still do matter to some makers, as can clearly be seen on this knife.
In use I found it held an edge well and was very easily stropped back to razor sharpness using only a piece of cardboard. Field maintenance was clearly a breeze. The blade is forming a bit of a patina, and in a few weeks I expect the edge to be as dark as the flats.
Whether I'm fishing, camping, hiking, or otherwise "in the field," I think this can and will do it all. It's compact, sturdy, and comfortable, with an edge geometry that cuts cleanly, drills nicely, maintains easily, can handle tough chores and still pick out a splinter without tearing a hole in my hand. For everything I want in a knife, and with everything I know about how they are built and how they perform, I would still be hard pressed to design a knife better than this. I will be getting a Fiddleback Terrasaur soon, which is another super-clean design I've been wanting to try out. So the AA Forge Scandi Bushcrafter will soon have a worthy contestant, and I may have to post a follow-up once these two have gone head-to-head.
Thank you Adam for the fantastic knife, and thank you all for reading!
Thank you very much for the review Cap!
I'm glad to see your enjoying it.
Now I'm really getting jittery waiting for my custom from Adam....man he makes some beautiful knives. I am really liking the kydex sheaths from Gray Wolf Knives. I looked on his site and even the Spec Ops sheath makes his knives look right at home.
Great review and thanks for the info. I have been eyeing his work for a while. Could you provide any specs on the width of the handle from the ricasso, mid point and the butt? This will help me decide if I need him to add a liner or go thicker on the slabs. Arthitis sucks by the way.
Happy to be of service... the handle width at the very top of the handle is 7/16", the bottom of the finger bevels is about 11/16", and the middle and butt are both 3/4".
Recently got a #5 from Aaron Gray
(4" Scandi Bushcraft woodlore clone)
And excellent knife
I will post a full review
He makes some great looking blades, for sure. Thanks for the review. :thumbup:
I'll chime in here... I bought a camp knife from him and a pocket leather pouch. Both are fantastic! Prices and wait times are reasonable and the quality is top notch.
Your bushie is sweet looking. Thanks for sharing.
Agreed, a great design and one of the sharpest I have received from a maker as well. Here is a photo of mine taken right after I got it. It has seen some use since then but has held up really well. One of my favorites and a lot of knife for its size. The handle is just right for me, not too big (thick), not too small (thin). Its size makes it very easy to carry and you forget you have it on your belt. I would certainly recommend it to anyone looking for a scandi bushcrafter.
Ooh, lucky! That looks like a cocobolo handled one I passed on and regretted ever since. If I'm thinking of what you have, then congrats and thank you for giving it a good home! I sometimes worry that good customs will end up with people who don't bother using them...
Thank you to all of you for the kind words.
I'm glad to see you guys are enjoying the knives!
Thanks for the well written review - I've been on the edge of purchasing one of Adam's knives for quite some time.
Scott
Glad to see Adam getting some props !! I have one of his tactical knives and I am on the list for a custom scandi. He pays attention to all the details. And I cant wait for my scandi to be done !!
