Adapting a 2" metal match for keychain carry
Howard Wallace
Moderator
I recently bought a couple of ferrocerium rods from Greg, in both the 4" x 3/8 dia and the 2" x 1/8 dia. The four inch one throws a slightly bigger spark, due to the greater length available for scraping. It also has a hole drilled through one end, so it can be put on a keychain or a lanyard. The 2" one throws an entirely adequate spark, but is harder to hold due to its small size. It does not have any hole or means of attachment to a keychain. I carried the big one for a couple of days on my keychain until I began to realize that the extra weight of the larger metal match was not justified by increased utility. I decided to modify the smaller one for keychain carry. Here's how I did it.
Find an old key that no longer fits anything. I looked for one with a large groove down the middle that I could set the metal match in. An old gas cap key for a car I no longer own fit the bill. Take the key to the grinder and extended the center groove up farther into the round handle of the key. Then grind off the serrations on each side of the key, so only the central groove and some supporting brass on each side is left.
Next fit a colored plastic key identifier over the head of the key. I got one of these plastic things at the hardware store for $0.25. This will serve to secure the metal match to the key. Next fill the groove in the key with epoxy, and set the match into the groove. Force the tip of the metal match up under the plastic covering on the head of the key. Then put epoxy in under the plastic cover also.
When the epoxy sets up you will have a metal match that weighs no more than a standard key. There is more available striking surface, as you can hold onto the key head rather than the tip of the ferrocerium rod. The brightly colored plastic head on the key will help you to spot the metal match if you drop it.
[This message has been edited by Howard Wallace (edited 02-27-2000).]
howard,
what a great idea.... great job improvising. can you send me a picture.
best
Greg Davenport
http://www.ssurvival.com
Are You Ready For The Challenge?
Are You Ready To Learn The Art Of Wilderness Survival?
Howard --
Nice combo. Metal match, whistle, Photon II. Who could ask for anything more!
...the LORD said unto Joshua, Make thee sharp knives… (Joshua 5:2)
The original posting refers to "Greg." That is Greg Davenport:
http://www.simply-survival.com/
click on "our store"
You might also contact Bagheera who posts to this group. I bought two of the Swedish Fire Steel ferro rods from him and he will treat you right. He may be out of them at the present time, however. His Boy Scout troop sells them on occasion as a fundraiser. Search on "Bagheera" in this group, then click on his profile and you should get his email address.
Good luck.
Another option is to pick up s BSA hot spark - about the size of a key, small plastic handle & lanyard hole/key ring hole already set - about 3/16" diameter, 1.5-2" long ferro rod. Comes w/ a small striker, $2 at a boy scout supply store.
Sam
<font face="Verdana, Arial" size="2">Originally posted by Flotsam:
Sam
</font>
I carry one of these myself and they have gone up to $2.95! I now have firesteels from Bagheera and they are great but the BSA Hot Spark cannot be beaten for size and weight!!
