Adding jigging to smooth bone
Oldy
I purchased a cold steel mini trapper in smooth yellow bone,I got for $24.00 cnd which is a hell of a deal.my intention is to take a dremmel and do a very nice irregular jigging pattern. I do not like the newer text book jigging.i like a real cluster muck of jigging,one with no rhyme or reason.now my question is has anyone attempted this and what were your thoughts. Also how did you bring the sheen back to the bone.alsy might try to befuddled the dye job.any thoughts
I purchased a cold steel mini trapper in smooth yellow bone,I got for $24.00 cnd which is a hell of a deal.my intention is to take a dremmel and do a very nice irregular jigging pattern. I do not like the newer text book jigging.i like a real cluster fruck of jigging,one with no rhyme or reason.now my question is has anyone attempted this and what were your thoughts. Also how did you bring the sheen back to the bone.alsy might try to befuddled the dye job.any thoughts
Haven't tried it yet myself but I hear it stinks something awful.
Maybe consider wearing a dust mask - and lighting some incense or something...
I watched this a bunch of times and just went nuts with a Dremel on some scrap ebony for practice.
Haven't gotten the smooth bone dyed yet to try it out on the real thing. Hopefully soon.
Had my nose busted and set more than once,smelling is not my strength lol
Rick huff how did it turn out,do you plan to put a coating on or just buff in a shine.
It turned out well on the ebony wood scraps. I was just trying to get a feel for it with different burrs and wheels. Best thing about it is that you really can't screw it up if you are not going for any sort of pattern! Haha
I plan to just give the bone a quick hit with some red and white rouge on the buffer. No coatings.
Im still kind of feeling this out so take it with a grain of salt!
Sounds good Rick,I really liked that worm pattern on those Charlie's harness jack. But I'd imagine once the jiggingmis done I will probably have penetrated the depth of the dye and would be left with the natural bone color.heck that might be an interesting look,but probably not it will need some coloring,a rust red over yellow hmmml
I've tried to add jigging to wood, plastic (delrin, I think), and bone scales. I've used various tools, including the tip of knife blade, rotary tools, and (of all things) the tip of the package opener on the Leatherman Wingman. I wasn't really happy with any of the results.
Here are some tips that I learned from my jigging attempts:
It takes a very careful, light touch with a a rotary tool to avoid cutting too deep or long. Try to keep your cuts shallow and short at first; you can always make them deeper later.
It's a good idea to mark out your jigging pattern on the scale before you start cutting. Even if you're aiming for an "irregular" pattern, you can still plan it out to look aesthetically pleasing. The first time I tried jigging, I didn't think to plan it out, I didn't consider how close together the cuts should be, and some of the troughs and grooves that I cut merged together. The resulting gouges and troughs looked more like chewing marks than a jigging pattern.
Hand tools (especially those not intended for bone) can slip on bone and leave scratches where you didn't want them, or even stab into your other hand.
My recommendation is to start by practicing (or developing) your jigging technique on sacrificial materials (like scrap wood) before you try it on your knife's scales. Wood will behave differently from bone because it's usually softer, but it's easier to find than bone. Both materials have a similar grain structure and you'll learn which rotary tool attachments work best, how to angle your cuts to work with the grain, how long and deep to make each cut, how close together the cuts should be, etc.
Changed to muck,I thought fruck sounded like a restaurant name.like fruckers.
When my sister was little she couldn't pronounce "Kentucky" so the restaurant chain, according to her, was called "F*cky Fried Chicken" - we'd all blush when she'd say it in public. 🤣
This is a practice on a boker gentlemans knife,I was given a warranty replacement.so been messing around,top one is my new jigging and bottom original
