- Nov 9, 2006
I'm working with some carbon steels and am adding a vinegar patina. I'm curious when do others put the patina on and how do you deal with the spine, handle are in terms of finishing them up after epoxy.
For example, I just dipped an unhandled blade so the patina came up partway of the tang, enough that the handle scales will cover it. For this first one, I'm going to finish the spine/handle area with satin. I'm hopeful the contrast between satin spine and patina blade will be interesting.
Other things I'm considering is dry fitting the scales and grinding them to shape and then dipping the entire blade so all edges have equal patina, or trying to blend patina on the spine/handle after everything is final shaped.
Thanks.
Thanks.
