Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
I'm going to dress up a Park Avenue folder by Benchmade Knives, the BM450 Terzuola Designed small folder.
My thoughts were to drill and tap, not sure the thread size to use or which screws to use...hence the post...two holes on each side to fasten small pieces of mammoth ivory onto the sides.
So questions are;
Drill to do the job on the mammoth
Screws that are small enough to not overwhelm the look of the knife
scales will be around 2 1/2" long by about 5/8" wide, also looking for a couple pieces of mammoth if someone has some kicking around that won't do them anygood but might work on this folder, please let me know...
Drill and tap for the above screws
I would hand shape the two pieces with files and sand paper to fit up to the knife as it is anodized aluminum and don't want to open up the anodizing...
So what do you guys recommend? I've only ever worked on fixed blade knives and never took on the detail work of adding scales, though I imagine this style will be about the easiest since it's an on lay and not needed to conform to a bolster or be a structural part of the folder, just to dress it up and to make it a bit thicker in the hand.
thanks in advance guys/gals,
G2
So questions are;
G2
