I've been making scales that go: Ebony "bolster" | 0.016" strip of copper | main wood scale -- all on a PVC/vinyl liner. I usually used to glue them up with epoxy -- G-flex or a long-cure BSI, say, on a G-10 liner, which worked great.
On the advice of the guys down at TruGrit, I started trying their PVC/vinyl liner material and the extra-thick Maxi-Cure 10-25 sec setup CA glue (the pink bottle), partly just due to time-savings. I was a little nervous, but I've got 3 6mm pins in the wood and a 3mm pin in the ebony for belt-and-suspenders so I felt OK about it. (Also I scuff up all surfaces and clean everything really well with acetone then EtOH.)
BUT the dang copper strip does not like to stick to the wood, if there's any flex before I get the scale on the blade. This wasn't a problem with the G-10 and epoxy, partly because the G-10 barely flexes and the vinyl does, and partly because of epoxy vs. CA under that kind of force. The Cu will stay stuck to one side/wood or the other, and I usually just wait until just before putting the scale on the knife and final glue-up and then get another drop of CA in there, press it tight, and glue it all up - I'm sure it's not going to separate laterally later! - but it just bugs me that I'm not getting a good bond in the first place, first time around.
Any thoughts?
Any thoughts?
