Well, I'm not actually doing anything to a knife.... I have a Kimber PepperBlaster II pepper spray gun. The frame is plastic, I think ABS but I'm not sure. I can't drill and tape holes into it because the components inside, but I want to attach a pocket clip from an old Benchmade that I have. Already tested it with some Loctite Epoxy Weld and it was a good principle, but that particular epoxy did not hold the clip on.
I haven't had really good luck with that particular type of epoxy in the past for other things anyway, so I think I'm going to try something else. Curious if any of you guys have used an adhesive to attach a pocket clip before. I think it's kind of a tall order for the adhesive since the way the clip imparts stress is a little bit like a lever... Small amount of force on the end of the clip, lots of stress at the bonding joint.
Thinking about this stuff...
http://www.loctiteproducts.com/p/epxy_plstc_s/overview/Loctite-Epoxy-Plastic-Bonder.htm
