Adjusting the Buck/Strider SP?
On all my other one handers there is a set part on one side of the pivot and a larger adjustable screw on the other. The Buck/Strider has two identical torx heads on both sides.
Is this supposed to be non-adjustible or are you supposed to hold one side while turning the other? Which side are you supposed to turn?
BTW, my action is fine. I'm just curious to know how it's done should the need ever arise.
Thanks,
Alex
I've adjusted mine by using two Torx drivers of identical size (I believe they are T10) and only turning the one on the thumb stud side of the knife. It may work on the other side but I haven't tried that yet. Good luck!
Thanks Dexter.
I was wondering if on side was male and the other side female. I'm assuming you would adjust the male side, but you can't tell which is which unless you take it apart.:confused:
