Advantages of fountain pens:
- smoother writers
- availability of different nibs provide line variation. You can get different nib sizes (xf, f, med, broad) and nib cuts (italic, stub, oblique, etc.)
- wide variety of ink colors available (can even mix to get the shade you want)
- wide variety of pen styles: vintage, modern retro, modern high-tech, custom . . .
- obligatory knife content: did you know that knifemaker David Broadwell makes custom fountain pens? Did you know that Grayson Tighe makes custom fountain pens?
http://www.david.broadwell.com/pens.html
http://www.tighepen.com/
- actually, you CAN get a nib that will write on carbon copies--in vintage pens, this is called a "manifold nib." For a modern pen with a stiff nib, most Watermans would fit the bill.
By using a fountain pen, you are preserving a bit of history that would otherwise be lost. They are not that much more expensive than other fine pens, unless you are buying a limited edition. In fact, is often said that $20-$100 fountain pens are better writers than $200-$400 fountain pens! Leakage is not an issue with modern fountain pens, and as for maintenance--just flush with cool water between refills!
Excellent sub-$100 FP's include the Lamy Safari, the Pelikan 200, and the Waterman Phileas or Laureat.
I heartily second GarageBoy's recommendation of the Pentrace forum. This is to fountain pen lovers what Bladeforums is to knife users.
C'mon . . . join the fountain pen revolution!
